Tweaked the tune, adjusted the boost controller to give a rising curve to fill in the natural power drop of this motor after 5500rpm. So far I like it. Initially it hits 7psi below 3000rpm...then 10psi to about 4500rpm then to 13lbs at 6000rpm with it dropping off at 7000. I typically shift at 6200rpm, with flat shifts sometimes spiking 6700rpm. Its a smooth progressive curve, no jumps or steps in power.
I also fine tuned the BC to limit part throttle boost, again to make the power more linear and help keep from seeing 12psi at 35% throttle lol
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2023/10/19/1697765281_20231012_094604_mmthumb.jpg)
I made a couple new rear muffler sections in the last couple weeks.
First off, I got this 5zigen Fireball replica muffler about 6months ago.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2023/10/19/1697765378_20230428_103323_mmthumb.jpg)
I repacked it before even using. I have a Spoon ITB replica muffler from the same company which I already repacked and knew they do not put much in to begin with. Cutting this one revealed what I saw in the Spoon rep...
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2023/10/19/1697765467_20231010_121559_mmthumb.jpg)
I already purchased ceramic mat to pack into this muffler.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2023/10/19/1697765501_20231010_122645_mmthumb.jpg)
Whipped up a new rear section, gave it some gangster JDM angle yo. And I dunno just didnt feel it. Flat bottom bumper cars make stuff like this look a little goofy. It sounded good, but with that large tip it boomed a little bit.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2023/10/19/1697765670_20231011_113325_mmthumb.jpg)
That lasted about a week lol so today I cut that up, saved the muffler for another day. I fitted one of the Bstock mufflers I keep in the shop, its a straight-thru SS no name unit. I really like these and they always surprise me how well they behave. I also have one on Floyd, my pink tercel and my Highlander.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2023/10/19/1697766119_20231019_134908_mmthumb.jpg)
This muffler is just perfect. Nice clean sound, very subtle. No drone at all. Still has some character. This will likely be the muffler that stays. I still have the Spoon rep rear section if I want to be noisy...that has a nice crisp sound.
I had another rear section I made with an Edelbrock RPM muffler. I liked it but it was just too flat sounding. Ill save that for another project.
