I figured I would post this up here as you guys are a little more forgiving of mistakes and kludges than the MT.net guys. I'll obviously try to avoid those things, but given my poor track record on projects I feel a little better about exposing my foibles on here.
Originally I was just going to be adding an MS3 to my car since I already had the thing setup with a Greddy, an intercooler, bigger downpipe and what not and just needed to get off the band aid setup (AFPR + Bipes timing controller etc) and start using bigger injectors and an actual computer. Then I broke a manifold to turbo stud.
So, here is my ugly setup with the stripes IC and the turbo tony downpipe. This is with the heat shield removed from the turbo.
Even if the car sits out that lower panel probably shouldn't be black.
I'm thinking that's possibly due to this leaking...
That's the ATP Turbo hose that I'm using for the oil return (yes it runs all the way around the engine bay), which is some very thick stuff, but that end is toast. The cracks go all the way through. I think I might need to grind down the lip on the turbo oil return outlet, because that hose was nearly impossible to get on there and I'm thinking the stretching probably contributed to its deterioration. As it is though the rest of the hose looks fine so I'm probably just going to clip that end off and put the hose back on.
I did manage to get the manifold off without breaking anything, but the later attempt to remove the turbo from the manifold ended up breaking off two more studs. The first attempt got one stud off and we were feeling good, but then the other two just broke right off.
The turbo looks okay, spins fine, but definitely a gray to white coating on the fins indicating I've run lean. Not surprising with the bandaids and the inexact nature of the tuning. Probably the only thing that has saved me is that I only autocross the car for the most part.
I ordered a new 10mm stud kit for the turbo to manifold connection and we'll see if the manifold can be drilled out for 10mm. A friend has taken it to a machine shop for me after we aborted a try at a DIY fix.
I also ordered an upgraded PCV valve as I'm noticing some oil getting out from the system, I installed that, but I think the spring clamps on that hose have given up the ghost so I need to get some new clamps.
I also got new Mazda Comp motor mounts installed and I must say it is really easy to install them when the manifold is completely removed.
How's that for easy access to the driver's side mount?
This is the old driver's side mount. Nice crack!
This is the other side of that same mount. Hello crack! So, it was a worthwhile exercise to replace them.
This is the view from the passenger side wheel well. The empty holes are where the mount lives normally. Please to ignore rust and dirt as this car sits outside a lot and gets detailed infrequently. It is extremely easy to remove the passenger side mount from in here whereas pulling it out and up past the intake manifold would suck. I will say that it's easier to break loose the bolts from up top, but you can pull the whole mount assembly out through the wheel well.
My major mess up so far is that I had the AIT bung welded to the intercooler, got it back, started to screw the AIT sensor into the bung and then I met some slight resistance. This is the part where you stop and reexamine, which I did, then I put it in again, some more resistance, this time I hit it with a wrench for a turn and that was it, cross threaded it. Idiot! I pulled it out with the impact wrench because it was jammed in really well and then got so pissed that I just blasted the thing back into the hole under the theory that if it was jammed in that well it would just stay there.
Then I came to my senses and ordered another sensor and bung. Back to the welder with my idiocy on full display. This is probably for the best as he welded the bung onto the wrong side of the intercooler and the sensor was pointing forward instead of backward. I hesitate to blame him for this as it is quite possible I just marked the wrong place on the thing. I figure he can cut the busted bung out, close it up and weld the new one onto the other side. Failing that the IC is $70 from cxracing. I feel pretty bad overall for letting that whole situation get away from me.
