1 ... 13 14 15 16 17 ... 21
6/17/20 2:13 p.m.
Ah. Cool!
TheV8Kid
TheV8Kid Dork
6/17/20 5:00 p.m.
Had to move the staging brake.
wheels777
wheels777 SuperDork
6/18/20 7:30 p.m.
Discarded and we put them on a shelf for years.
Add calipers that were discarded 3+ years ago.
You'll like what we did with them laugh
Bent-Valve (FS)
Bent-Valve (FS) Dork
6/18/20 7:53 p.m.
Go ahead make us wait.
Well, we're waiting....
cheeky
Bent-Valve (FS)
6/18/20 7:56 p.m.
Honestly,  it has popped into my head several times.
You should call this the "Millennium Falcon"
You know, "the fastest hunk of junk..."
759NRNG (Forum Partidario)
759NRNG (Forum Partidario) UltraDork
6/18/20 9:17 p.m.
You're cast away parts collection is in some circles to DIE for...... How far are we from NOISE!?!?!?!!!!
TheV8Kid
TheV8Kid Dork
6/18/20 9:21 p.m.
In reply to 759NRNG (Forum Partidario) :
It already is making noise. Check out the last page.
6/18/20 9:31 p.m.
before this last page??
wheels777
wheels777 SuperDork
6/19/20 2:53 a.m.
4 days ago. See post on 6/14 @ 8:34pm
TheV8Kid
TheV8Kid Dork
6/19/20 6:41 a.m.
TheV8Kid said:
So pumped about it, I'll post it again!
TheV8Kid
TheV8Kid Dork
6/19/20 9:56 a.m.
Speaking of the car running...
wheels777
wheels777 SuperDork
6/19/20 4:27 p.m.
cheeky
Blast, sand, paint, listen to the nay-sayers scream.
Bent-Valve (FS)
6/19/20 4:52 p.m.
cheeky
And it was worth the wait. Looks nice.
smiley
Different question. This is scrap reworked, would a rebuild kit be budget neutral or how would you figure these brakes?
wheels777
wheels777 SuperDork
6/19/20 5:03 p.m.
In reply to Bent-Valve (FS) :
We would budget it in if it was required.
6/19/20 6:20 p.m.
TheV8Kid said:
THANK YOU
wheels777
wheels777 SuperDork
6/19/20 7:06 p.m.
6/19/20 9:05 p.m.
Ok I'll bite why would we want to see the wheel speed sensor gear thingy ? or is that the whole point....which one of you knuckleheads can identify this scenario.....perhaps?
TheV8Kid
TheV8Kid Dork
6/19/20 9:11 p.m.
That's just the way that the hub is designed. At some point we will add a wheels speed sensor to the rear as well in order to do closed loop traction control.
So cool to watch you guys diagnose issues in realtime in the videos.
What were you checking with the temp gun?
TheV8Kid
TheV8Kid Dork
6/20/20 9:01 p.m.
In reply to CrustyRedXpress (Forum Supporter) :
We seeing if all the cylinders were firing. You will see a lot lowered temperature on the exhaust port if you have a dead hole.
Bent-Valve (FS)
6/20/20 10:09 p.m.
At first I thought "I imagine that is going to be a headache on this machine"
But then I thought about "closed loop"
And the pulse / control system needed to release / apply braking.
I'm back to I think this might be a headache.
Unless I'm completely off course, wouldn't be the first time.
wvumtnbkr
wvumtnbkr GRM+ Memberand UberDork
6/21/20 6:06 a.m.
I would think it would be easier to mess with power delivery than brakes.  Mess with timing, not brakes for instance.
TheV8Kid
TheV8Kid Dork
6/21/20 12:11 p.m.
In reply to wvumtnbkr :
What he said.
Bent-Valve (FS)
6/21/20 1:00 p.m.
That makes sense.
I just hate when traction control removes power, it really throws me off. If I want less power my right foot is programmed to lift.
The CR-V would play with brakes and then as you push it farther reduce power to prevent you from doing something stupid. Of course I was trying to do something stupid.
The Panther body drops power first. The traction control button is a simple on off push button so I do like that.
Will you program it to drop all power if you go full brake?
TheV8Kid
TheV8Kid Dork
6/21/20 1:33 p.m.
5 minutes after starting the car for the first time...
650whp!! And a laundry list of changes to make.
XrhBXBf5Vf1zsSEvxz2tv4MjILnOdP6rKJxks1jShKqjO3YEGVML1TzZCKdinfBT
