1 ... 30 31 32
TheV8Kid
TheV8Kid Dork
4/18/21 9:28 p.m.
In reply to OHSCrifle :
It's test and tune. Have to build boost before launch. Decided not to use the bump box.
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
4/19/21 7:04 a.m.
In reply to TheV8Kid :
What's the button your Dad was holding just before launch?
Gimp (Forum Supporter)
Gimp (Forum Supporter) GRM+ Memberand UltraDork
4/19/21 8:10 a.m.
Assuming the trans brake.
wheels777
wheels777 UltraDork
4/19/21 12:34 p.m.
Trans brake.
JoeyM
JoeyM GRM+ Memberand Mod Squad
4/22/21 8:41 p.m.
TheV8Kid said:
This is the in car of the 8.75 pass made before the 8.62 pass.
those times are astonishing....just WOW
wheels777
wheels777 UltraDork
4/23/21 5:21 p.m.
Thanks Joey,  we got a lot of work to do to get it where we are wanting to go.   We have 3.64 gears and need 3.15, and we need the get more rear shock extension.  Then we can add more boost. It's going to be a ride when it's done.
wheels777
wheels777 UltraDork
4/28/21 8:36 p.m.
Custom pinion retainer to support a 40 spline input shaft, 9.5" ring gear, 1350 yoke, Pro Gear, 3.812" side bearing 3.20:1... getting closer
759NRNG
759NRNG UberDork
4/28/21 8:40 p.m.
wheels777 said:
Custom pinion retainer to support a 40 spline input shaft, 1350 yoke, Pro Gear, 4.25" side bearing 3.20:1... getting closer
Because  what you had before was a.....???
wheels777
wheels777 UltraDork
4/28/21 9:03 p.m.
759NRNG said:
wheels777 said:
Custom pinion retainer to support a 40 spline input shaft, 1350 yoke, Pro Gear, 3.812" side bearing 3.20:1... getting closer
Because  what you hasd before was a.....???
9", non-Pro Gear, iron center, 28 spline input, 3.25" side bearing, 3.64:1 gear set
I forgot to mention earlier that it's a 9.5" ring gear.
wheels777
wheels777 UltraDork
5/23/21 7:06 a.m.
bluej (Forum Supporter)
bluej (Forum Supporter) PowerDork
5/24/21 1:56 p.m.
This made me actually laugh after a somber morning. you guys are clearly having a good time laugh
wheels777
wheels777 UltraDork
5/24/21 4:56 p.m.
Dustin has become a good friend.
wheels777
wheels777 UltraDork
5/30/21 1:16 p.m.
759NRNG
759NRNG UberDork
6/13/21 2:22 p.m.
The X-BOMB IZ DA BOMB!!!!!! just now got to watch this. More than anything else, you two and y'alls execution of fabrication is amazing.....nothing fancy , but well laid out and most of all FUNCTIONAL!!! ......oh and I really dig the rims. What rear tire(width) is on this?Carry on O' merchants of chaos and mayhem!!!!wink
wheels777
wheels777 UltraDork
6/14/21 5:08 a.m.
In reply to 759NRNG :
Thank you.  We will be doing a number of improvements soon and hope to get back to the track in 2 months.
759NRNG
759NRNG UberDork
6/14/21 8:24 p.m.
Are those 10.5" slicks?  What are your rims ?
wheels777
wheels777 UltraDork
6/15/21 5:04 a.m.
28"x10.5" MT slicks on 15"x10" Welds painted with VHT chassis paint.
759NRNG
759NRNG UberDork
11/2/21 5:39 p.m.
Andrew, this was the first recognizable thread from y'all in my watch list......kinda  of  hi-jack but was very interested in the photos of you at the challenge doing the AX in the sunbird. What do you do to go from 9 second blasts to dodging cones setup wise?
wheels777
wheels777 UltraDork
11/2/21 10:48 p.m.
Bugzilla did the best at the Auto-X finishing 2nd and 6th. The Fiat finished 9th.  Both of these cars had alignment changes between the A-x and Drag events.  Changes included camber, caster and toe adjustments.
We did not change anything on the Sunbird. If it is brought back, we will add a front sway bar and much better tires.  We may consider toe changes.  The car has huge potential but we did nothing to help that area as our budget was used to help the drag time specifically.
TheWraith
TheWraith New Reader
11/3/21 8:14 p.m.
Just read it all, great build!
759NRNG
759NRNG UberDork
4/22/22 9:23 p.m.
Andrew, Calvin, Caleb and Ms. Pat throwing this to the top haven't heard from any of you honyoks..miss y'alls smack. Hey what is a realistic price for a custom drive shaft (lengthened 1350)?
wheels777
wheels777 UltraDork
4/23/22 8:20 a.m.
Do you mean Cameron and Paula?
Driveshaft will be between $485 and $700 depending on the material (steel or aluminum).
What is a honyoke?  I don't know if that indearing or other.
759NRNG
759NRNG UberDork
4/23/22 9:07 a.m.
Andrew my sincere apologies to Ms. Paula and Cameron.....Honyok is not exactly enduring at all only when used in the company of those that you know can take a smack upside the head and still be friends
1 ... 30 31 32
dJeu4JiEh25x0rgNmRCJEkYjY5ihy3QDeBaELXRMVASecXV1H10ZyglKjPwlRR4o
