1 ... 4 5 6 7 8
GIRTHQUAKE
GIRTHQUAKE Dork
5/23/20 11:37 a.m.
What do you use for the LED Headlamps?
Ben_Modified
Ben_Modified HalfDork
5/23/20 11:51 a.m.
They are aftermarket intended for late model jeep.  I can get you the name if you want.
jfryjfry (Forum Supporter)
jfryjfry (Forum Supporter) Dork
5/23/20 3:23 p.m.
I have a brand new sunroof I bought that I won't use.  It has a frame and everything needed.   Let me know if you'd be interested.  Username at yahoo
Ben_Modified
5/23/20 6:27 p.m.
In reply to jfryjfry (Forum Supporter) :
Thanks, I will send you an email.
GIRTHQUAKE
GIRTHQUAKE Dork
5/23/20 9:46 p.m.
Maybe- are they particularly cheap or easy to work with? Like do they have internal ballasts or heat sinks? I'm looking for some great "general" ones for my future rodding-out projects.
OjaiM5
OjaiM5 Reader
5/26/20 6:55 p.m.
Did a lil' napkin sketch
Ben_Modified
5/26/20 8:49 p.m.
Wow, that it so cool! Thank you!!
OjaiM5
OjaiM5 Reader
5/26/20 8:54 p.m.
Thank you for entertaining us with all your crazy builds!
Ben_Modified
5/26/20 9:02 p.m.
Here are a couple of photos.  I have not used them yet, but they seem simple.  I do not plan to use the module for the multicolor running lights
Ben_Modified
5/26/20 9:03 p.m.
In reply to OjaiM5 :
Wow, really impressive!  Can't thank you enough!
Ben_Modified
5/27/20 11:45 a.m.
Would it be all right if I post this other places? if that's okay, would you like some sort of an artist credit given? Thanks
OjaiM5
OjaiM5 Reader
5/27/20 12:26 p.m.
Yeah of of course, maybe I can do a cleaner version for you. That was a quickie
Ben_Modified
5/27/20 12:50 p.m.
I would not ask that of you.....but if you are volunteering
OjaiM5
OjaiM5 Reader
5/27/20 2:34 p.m.
Here is a new version......
Ben_Modified
5/27/20 3:04 p.m.
Thanks!! Nice job, that was quick! I see you even incorporated my "yet to be installed" flat glass windshield.  Now I know it will look right!
I really appreciate it!
OjaiM5
OjaiM5 Reader
5/27/20 3:07 p.m.
De Nada!
Ben_Modified
5/30/20 4:10 a.m.
Well there is no going back now!
Tilt out safari window going in.
5/30/20 5:43 a.m.
In reply to Ben_Modified :
Wow!
eastpark
eastpark Reader
5/30/20 3:52 p.m.
I've been following your channel, you have a great eye for this Ben. At the beginning of the video I thought "no way" - boy, was I wrong. It's looking great!
Ben_Modified
5/31/20 2:39 a.m.
Thanks! I have to admit there were a few moments of panic along the way but I think it will look just fine when done. The safari glass is one of my favorite features on my VW Bus. Can't wait to finish this up!
Ben_Modified
6/2/20 6:51 p.m.
Safari temporary in place and open.  The roof panel helps a lot with blending things together.
Ben_Modified
6/5/20 4:41 a.m.
One side mostly done.  Still need to trim and smooth the sharp angle at the lower corner of the windshield frame.
Ben_Modified
6/6/20 7:58 p.m.
I am reshaping the front door window frames to run parallel to the roof line and now slimmer A pillar. Only the right hand side done so far.
6/7/20 12:22 a.m.
Wow!
Ben_Modified
6/9/20 6:14 p.m.
The exterior sheet metal work is done on the Safari windshield. Still have to finish the door jambs and door window frames.
1 ... 4 5 6 7 8
ryaQKBwcgPAqByoZKfRjBxDTGi5sEheVjnnRNPxcAc2EGYcn2fLTpQHtFPMRmqAO
