Well, if you saw it in the rant thread, the new engine is blown sky-high. I never fired it. I was cranking it with the fuel pump fuse unplugged, to build oil pressure before trying to fire it, and cranking compression was blowing the coolant out of the reservoir. And there's an external leak at around number 3.
So, options. I have sought contact with the yard who sold the engine. I did this through eBay's messaging system. The engine was purchased with PayPal Credit because they offered a 12 month period at zero interest. I have not yet left feedback on the purchase.
I am fortunate enough to have free rein to use the shop loaners, which works for getting me back and forth to work, but they are usually gone during the day which means no going out for lunch. Also, I have an all wheel drive car with new Blizzaks, I do not want to be driving a 5 year old Fit or Focus on all-seasons. And as I type this, it is sleeting and will turn to snow.
Options. 2.4 engines are very thin on the ground. Nearest junkyard on car-part is in Michigan, next closest is in New York. 2.5 is not an option, I want a more permanent fix than loading another time bomb into the chamber.
I am loathe to pull the 2.4 engine apart until I know what is going on, but my 2.5 is conveniently powering an engine stand. I'll pull the head off and see if the head is warped. (Must buy straightedge off of tool truck tomorrow) If its deck is flat, and I can readily identify cracks in the bores, I will qualify the head as an asset.
The next step would be to pull the head off of the 2.4 and see what is going on in there. If the block checks flat and the bores appear uncracked, I'll pop the 2.5 head on it with the head gasket set that I bought for the 5 million seals and O-rings. (And I will shim the block at the same time, I am not a fool)
I'd love to say "fark it, throw the 2.5 and stock downpipe back in with the O2 "adaptor", trade it in on something else", but to be honest, there's nothing else I could buy that I would not consider a downgrade. So it makes sense to persevere.
