This is barely worth posting about, but I guess some progress is better than none. Here is a steering column mod. It's an 80's Jeep XJ column from the junkyard. I chose this because it's a very simple, minimalist design with tilt, and it was 30 bucks. Two things though. It's the wrong color, and it has a column ignition tumbler, which needs to be shaved off for vain reasons. I want the ignition in the dashboard, because I plan to retain the original Lexus key and ignition switch, for the LOLz, and also I might have berkeleyed the tumbler real bad by drilling it out when trying to un-lock the column. You can buy a quality tilting street rod column for about $400, or you can do this.
I accidentally disassembled too far, but I re-greased the bearings and tilt u-joint while I was in there, using only the finest Park Tools bicycle bearing grease since I guess that's what I had. Also deleted are the column locking mechanisms associated with the tumbler.
Ah yes, the aesthetically offensive part which must be remedied.
With the tumbler housing shaved, I filled the gap with a few layers of JB weld reinforced with a 1/2" washer.
And more JB weld.
And then less JB weld.
Topped off with some primer and satin black.
If you own a Jeep XJ and want to do an ignition delete, consider this write-up.
While I had the JB weld out, I also fixed a fitment issue with the windshield tilt brackets. At full close, there was still a small gap to the body, so I needed to somehow make the brackets pull the windshield frame closer to the body. I did this by slotting the swage nut hole, and bonding the swage nut to the bracket with JB weld while filling the slot.
Unless the windshield is tilted all the way out, you'll never see this tweak.
