Jul 11, 2018
DAY TWO
So far I am on schedule.
Day one to remove all the excess parts that I am accumulated over the years in preparation for when I was ready to restore the car. (Done!)
Day two, as expected, took a very long time. I just wanted to capture all the neat modifications (and everything is modified!) in the car to set a base for the project. It is always nice to go back to photos to see where one started and to help putting everything back together.
I took a lot of photos and saved them HERE
Below, I captured a lot of the details that warrant sharing at this time.
I am still guessing how the rear suspension currently works. Wow!
I do wish I noticed that the car had grass clipping hanging from spider webs so that I could have cleaned up before taking the pictures. Oh well… one day I will have this on the lift to be able to get much better photos of the underside.
Front shot of the car. You can’t quite get a feel for how low the car is because it is on caster dollies, but I did measure from the bottom of the transmission (while car was on the dollies) and it was approximately 7.5” to the ground. The dollies raise the car approximately 2.75” for a difference of… carry the two and divide by zero… about 4.75”. You will see in the images below that the bottom of the transmission bell was cut off and there is a custom oil pan to give the car some ground clearance.
Of course, this will be a challenge with doing the 02M… assuming it is even possible with trying to keep the look of the car and not having a transmission 1” off the ground.
I will try to show in the pictures that follow how much the interior of the car has changed to move the driver closer to the center. The center tunnel has been moved towards the passenger side. You know, minor stuff like that.
Transmission is a 020 (typically Scirocco or Rabbit 5-speed) with the usual crazy spherical bearings for all connections from shifter to transmission. The shifter is also raised
A little help in the survivability department… additional bar in the (modified) center of the car.
Showing off the sexy fenders. Assuming I remember this correctly… the neat thing about the design of the fender was to allow this car to fit into the current rules that stated that the fender had to look stock from the side (stock profile, something like that). So, sure, looking dead-on 90-degrees at the side of the car, the straight out fender extension would technically not be visible, therefore, it meet the rule; it would not be considered modified/widened. Tricky. That lasted for one year.
Let’s move around to the rear. Lots of cage work and reinforcement (notice the added braces on the floor between the bulk head for the fuel system and the wheel wells.
Fuel system bulk head. I might add rubber seal to edge/lip.
Stuff inside that I need to determine exactly what is needed with my future setup.
Okay… what are we looking at here? Where the rear seat would normally go, the section is now flat and very structural. Hmmm… might have something to do with rear suspension. More below.
Another photo showing the location of the driver’s seat vs. the passenger seat.
Small passenger seat.
Let’s move to the engine. When Bill built this 1.8T MK1 Scirocco, it was the only one I knew of at the time. I am not saying he was first, they just weren’t on my radar. The point is that because putting 1.8T engines in MK1 was relatively new, resources for mounting the engine and making it run were very limited.
Notice how the extra large radiator is mounted… more body modification that serves a function.
Brakes and suspension. I am unsure if Bill modified existing vented brakes or purchased them… I have never seen cross drilling holes this large.
Suspension is the typical two step springs. I forgot to check spring rates when I had the wheel off.
The crazy modified oil pan and transmission. I am surprised that he did not have a skid plate.
Now things get interesting.
Equal length driver and passenger axles. Carrier bearing addresses the distance issue.
Not the best picture… I am trying to show the sub-frame. This should be helpful with the 02M installation as we can mount the dogbone (MK4 rear transmission mount to keep the engine in place) to the sub-frame.
And now to the rear of the car. I do recall that Bill used to run full independent in the rear. I thought he did away with that with future modifications. I’m still not quite sure how everything works at the moment. When I get the car on a lift, I can get a much better understanding.
Got the tape measure to show distance from the inside edge of the seat to the outside edge of the roll bar. (approximately) Driver 23” passenger 18”
More shows of the suspension, brakes, control arms, and flipped tie rod.
There is a lot of distance between the unibody and the edge of the fender. The car has 215 wide tires in the front. I think the rears are 185.
Well, that is about it for the night.
Thinks will get a little slower as I have to remove all the current wiring harness, take pictures and take notes, etc. to get the car rear for the fabrication and bodywork process. That will be a major stepping stone for this car.
Looking forward to it.
Oh… and the pictures should be uploaded “soon”… I’m on slow DSL and it will take some time to upload all the pictures.
First world problems, I know.
Enjoy!
Steve
