Early May 2019, new set of federals, 245/50r16
Back tires of course rubbed. But I was looking at the rear bump stop that was leftover from when I was running coilovers and it seemed like it was way too short. Suspension wise I think it is pretty close to stock ride height at this point, so I ordered some stock bump stops and did a heckin measure.
This probably makes the rear stops much more active, but it did the trick.
July 2019, finished a project I had started in 2015, polishing roof bars. Not perfect, but good enough for something that primarily is used to kill bugs at highway speed.
Also July 2019, my friend Bill and I loaded up and headed to MK1 Madness. Bill's black Jetta pictured here comes into the story in a couple years.
Dan met us at madness, it was a pretty awesome weekend hanging with them dudes and seeing some great cars. Boy was it hot, the drive was brutal pulling, the trailer. Bill assembled a beer box heat shield on top of the tunnel to help reduce the heat that was pouring into the car from the exhaust. Overall, awesome weekend. If you have a chance to go to Mk1 Madness, do it. Its an amazing weekend.
September 2019, the pressure line from the PS pump to the rack let go. I took the opportunity to make new lines, and add a small cooler into the return line. It probably doesn't do much but a little extra capacity is good. Here's the cooler mounted in the lower grill. Just welded some tabs to the bumper beam for it to bolt to.
Here are the new feed and return lines. I used -6AN, and learned that AN lines dont like doing high pressure like power steering.
So after the pressure line blew apart and dumped PS fluid all over the road, I re-made it from PTFE 6AN, this worked way more better.
Well that didnt fix all of the PS leak, and with some investigation, I found the hard lines on the rack were leaking, so I found a dude parting out a TT, and went to pick up the rack, arms and spindles from him. The rack that was in the TT was junk, but he had a clean stock mk4 rack that he hooked me up with instead, and I got the beloved TT spindles and arms. Out came the whole assembly.
Leaking hard lines in question
It was fun to check over all the parts on the subframe, clean up and clean all the gunk off.
Reassembled with the 1.8/VR spindles, and waited a week or so to swap the TT spindles and arms to have some time to change the bushings and wheel bearings in that stuff.
TT junk installed
End of September 2019, road trip down South to see Alex and his Wife on their summer vacation. We got to hang out and swapped cars for a bit on BRP.
We were all headed home in one shot but they had a much further drive than me, as they were going NC to NH. We rolled out early, Fueled up before the gas station was open apparently.
Sunrise in VA
Rolled back roads up to Huntington WV then grabbed the highway for the last bit back. It was a lot of hours of twisty roads, pretty solid day.
March 2020, in a real slick move I had jammed the door handle into the window clip access hole in the door. Then rolled down the window without thinking about it
So that resulted in a back burner project promptly becoming a priority. I had lexan to do the windows sitting around for almost a year. Here goes.
back windows got naca ducts
gangs all here
All this trash went in the trash.
August 2020, ignition tune up. plugs, wires, new coil.
tired plugs
Bill and I went on a Mk4 camping trip in VA and did some exploring, also August 2020.
back road exploring
Somewhere up on BRP again
I did a timing belt and water pump on Bill's Jetta shortly after this trip. A little rusty, but it's a pretty good car. Very similar to mine, 2.0, BEV motor, his is an auto though, leather, sunroof, whatever.
Thats it for now! Getting so close to caught up. Probably some more about Bill's car next time.
Mike
