Got the hood open by cutting thru the hood. The hood release itself was stuck shut. The weird thing is it wasn't stuck when I went and looked at it.
So I was trying to use this to remove the glue left over from the headliner but it isn't working worth crap. Any one have any suggestions?
a mixture of automotive paint thinner and wax & grease remover.
We used to use it all the time to remove the adhesive from the lettering on box trucks when I worked at the collision repair shop.
SyntheticBlinkerFluid wrote: a mixture of automotive paint thinner and wax & grease remover. We used to use it all the time to remove the adhesive from the lettering on box trucks when I worked at the collision repair shop.
Did you just mix it 50/50 and apply or apply them separately but at around the same time?
4cylndrfury wrote: best goo remover Ive found is good ol zippo fluid (mostly kerosene I think).
+1 Its naphtha.
93EXCivic wrote:SyntheticBlinkerFluid wrote: a mixture of automotive paint thinner and wax & grease remover. We used to use it all the time to remove the adhesive from the lettering on box trucks when I worked at the collision repair shop.Did you just mix it 50/50 and apply or apply them separately but at around the same time?
I use a 50/50 mix, Sometimes 60/40 and apply it with a rag, then usually scrape it with a putty knife/gasket scraper. Sometimes apply it twice then scrape.
Good idea to buy a gallon of each.
93EXCivic wrote:
You keep collecting this Yugo stuff and I'll have to break out the rare collectibles to tempt you. How about a dealership Yugo parts and service sign? Its lit and functional ;)
JThw8 wrote:93EXCivic wrote:You keep collecting this Yugo stuff and I'll have to break out the rare collectibles to tempt you. How about a dealership Yugo parts and service sign? Its lit and functional ;)
Pictures? I am trying to find stuff to put in my garage.
http://grassrootsmotorsports.com/forum/grm/what-paint-scheme/45601/page1/
So I am leaning towards an Alitalia paint scheme.
http://grassrootsmotorsports.com/forum/grm/kyb-spring-rates/45620/page1/
And trying to figure out the strut options. May involve an A1 VW front struts.
SyntheticBlinkerFluid wrote: How did the glue removal go?
Haven't completely yet. I am going to try so other things tomorrow after I clean up the floor pans.
Ok so there is a small hole near the seam in sill. The metal around it seems fairly solid. Should I just Bondo that small hole and put POR-15 over it or weld it up?
The roof rack is deleted and the holes filled in. The side trim is removed and I have removed a decent amount of rust from the passengers side.
Does anyone know of a cheap source for fender mirrors?
Do you think it would look bad to have the interior of the car painted black and the outside a different color?
So the hatch is kinda E36 M3ty. I am pretty sure that I can't really repair it correctly. If I coat it with POR-15, will I be able to get this decently smooth with some work?
