Intriguing to me that there's comments here as to the towing rating, but nothing as to the actual seat-of-the-pants power a truck like this is supposed to put down.
We've got comments about the ride quality, ease of ingress/egress, rear-seat leg-room, and how smooth it shifts, but no one giggling about smoking some poseur car at a stoplight?
You …
We did floor it. Then we had to buy gas.
Nashco
UberDork
11/22/10 7:11 p.m.
David...I hope not, since your test truck had a diesel engine!
I've got the Dodge equivalent - more or less. 2500 instead of 3500 means a better ride and still enough towing capacity to deal with anything I'm planning to hook up. I went for a 6-speed stick. It's not a drag racer, that's for sure - those gears don't last long before it's time to shift. But it's got that feeling of inevitability - if you want to go somewhere, nothing will stop you.
For the climbing in and out, get a set of running boards. Around here, every big truck has a set.
2wd trucks are for posers. Real trucks have 4wd.
No, they're quite different. The Cummins is an inline 6 real diesel (not to mention lower power) and the Duramax although impressive is really still a light duty V8 motor.
Also, you have a solid front axle and the Chevrolet has an independent.
You have more truck with a 3/4 than their tonner. I say this as the (regrettable) owner of a crew long Chevrolet tonner.
Did your hootus grow longer when you drove it?
Sadly, no, no reports of hootus enlargement.
Shaun
HalfDork
12/5/10 9:47 p.m.
The brakes as described in the spec field concern me. Although a lack of fade is desirable, I am not sure eliminating fade is worth eliminating the brakes entirely, and relying on trailer brakes would (obviously) necessitate towing a trailer at all times. Which is cool, true..., especially if you are towing a fleet of Miatas. But still, a truck should have a good set of binders, front and rear.
Sometimes you have to tow something big--like a race car trailer, a houseboat, or a small New England state. That's where monster trucks like the GMC Sierra 3500 HD come in. Properly configured, this beast can tow more than 21,000 pounds--that's like a fleet of Miatas.
Our test truck was nicely equipped to work. While the Vortec 6.0-liter V8 is standard, we had the 6.6-liter turbo-diesel Duramax backed by an Allison six-speed automatic. (Those are $7195 and $1200 options respectively, by the way.) The gross vehicle weight rating of this particular truck was a handy 11,500 pounds.
Other options included the SLE package ($980 to get dual-zone a/c, a six-way power driver's seat, USB port, fog lamps and some other thrills) plus $455 for the integrated trailer brake controller. Strip away the options, and the Sierra 3500 4WD Crew SRW SLE is a $40,485 truck.
Go with the most basic 3500 HD--regular cab, two-wheel drive and a long box--and you're looking at $28,805. Honestly, that's a lot of dragging capability for a reasonable price. Figure the wimpiest 3500 HD can tow at least 13,000 pounds. That's at least six Miatas, right?
