donalson
donalson SuperDork
3/13/10 12:44 p.m.
my '96 astro van has had starting issues seance last fall... van broke down and didn't run for a while and it's just finally getting warm enough to do work on things...
started with a simple cycling of the fuel pump a few times and it would start with out a prob... eventually got to the point that it wouldn't start without starter fluid... but once it was warm it would start no prob.
now as weather is warming up a bit some mornings I can get it started by cycling the fuel pump a few times.
1st thing I thought was fuel pump... but being that it's cold start related is there something else I should look at?
patgizz
patgizz GRM+ Memberand SuperDork
3/13/10 1:38 p.m.
injector spider bleeding down?
if you need any injector or intake related parts i've got a whole 96 astro engine sitting here that ran perfect and started every time so all the injection stuff is good here.
donalson
donalson SuperDork
3/13/10 2:56 p.m.
aka fuel pressure somewhere in there is leaking out?... grr... lol
John Brown
3/13/10 6:45 p.m.
Fuel pump
Kramer
Kramer HalfDork
3/13/10 7:51 p.m.
Fuel pressure regulator? About $50 at a parts store.
Nashco
Nashco SuperDork
3/14/10 1:43 a.m.
I'd definitely expect fuel pressure related, most likely worn fuel pump. The spiders from that era are particularly finicky about fuel pressure.
Bryce
Edit: Oh yeah, don't forget to check out the coolant temp sensor (and perhaps oxygen sensor).
Ie7eclFdAluUryjwCyJD7epV09lS8eTchnvNilyCg95S4FnA2R9nzQxszkm5OA3u
