MadScientistMatt
MadScientistMatt PowerDork
5/7/18 12:26 p.m.
So, I happened to need some 5/8" AN flared tubing. I ordered some tubing and flare nuts from Summit along with the tool their website recommended - only to find that the tool doesn't work on anything larger than 1/2", and most of the tools I've seen for flaring 5/8" tubing with a 37 degree flare have been in the $200 range. Any ideas on ones with better pricing? Harbor Freight tools appear to be in the 45 degree range instead.
HFmaxi
HFmaxi Reader
5/7/18 12:41 p.m.
pushrod36
pushrod36 Reader
5/7/18 1:56 p.m.
I used compression fittings when I had this problem.  I was even willing to spend the money, but the big problem was that I plain couldn't find a tool that would flare stainless.
I know a lot of folks don't like compression fittings, but I haven't had any issues.
MadScientistMatt
5/7/18 2:12 p.m.
Compression fittings might work if I can get an adapter to an AN O-ring type fitting that's on the turbo.
Papabear
Papabear New Reader
5/7/18 2:50 p.m.
Like HFmaxi said the Rigid 377 is a quality tool for this. I've done Cunifer, Steel and Stainless with it no problem.
44Dwarf
44Dwarf UberDork
5/7/18 3:18 p.m.
I've had this one for years from McMaster
https://www.mcmaster.com/#2691a14/=1cqpmds
What type of tubing are you using Mat?
MadScientistMatt
5/7/18 3:58 p.m.
Just aluminum, so no need for a tool that can flare stainless or even regular steel.
Uu3DKKsA6Y9F9vKwpwIypC1j31vdJzrY6FxgS0cNqVlXww1ZES9sfDxcvWexWhdy
