1 2 3 4
lnlds
lnlds New Reader
7/28/11 6:43 p.m.
what about vw's 1.8t? or 2.0t?
ProDarwin
ProDarwin Dork
7/28/11 6:49 p.m.
sanman wrote: Don't forget the 2 liter boxer turbo motor out of the bugeye wrx.
Its not an Inline engine.
oldeskewltoy
oldeskewltoy Reader
7/28/11 7:13 p.m.
GameboyRMH wrote: Just mental masturbation over My Ideal Car, don't act like you don't do it too
I've managed to get my rolla down the 1/4 in 15.7, and I SUCK @ drag racing, a decent driver should be able to get my car down the 1/4 in sub 15 seconds... and that is running 3.72 final drive instead of 4AGE typical final drives of 4.30
MY 4AGE carries about 25-30#/ft more torque than most 4AGEs, and I still get 30+ mpg on the highway. She is also emissions friendly.
Want more torque... try a Rotrex on a 4AGE, gentleman in the UK has a locost/locust with a rotex mounted to a 4AGE and he's planting 260+hp, and over 175#/ft
7/28/11 7:23 p.m.
If we are going non-inline. I vote for the lancia V4
T.J.
T.J. SuperDork
7/28/11 7:30 p.m.
BMW M10?
Ok, not really, but the versions that found their way into Formula 1 sure put out a lot of power. The amount seems to grow with each passing year.
I would like a F20C in something. If the engine is to mounted the wrong way, a K20 would do it for me. I would also place a vote for the ECOTEC.
Taiden
Taiden HalfDork
7/28/11 7:35 p.m.
SR20VE
$800 at any importer
drops into any FWD sr20 powered vehicle with no modifications
friend gets 38 mpg with a 15:1 afr cruise
/endthread
HStockSolo
HStockSolo New Reader
7/28/11 8:17 p.m.
My favorite I4 was the 1.8L DOHC Isuzu 4XF1 in my Geo. Small and can make a lot of power, but not exactly light. Very different from the 1.9L Saturn LL0. That I mainly like for being light.
Of course, I'd take a 3.0L Porsche I4.
kb58
kb58 HalfDork
7/28/11 8:49 p.m.
K-series transmissions take a dump at anything much above stock power levels. Not exactly engine-related, but it is drivetrain-related. It can be fixed (straight-cut gears) for about $5000. Really.
Nitroracer
Nitroracer SuperDork
7/28/11 9:08 p.m.
DaveEstey wrote: The new twin-turbo (yes you heard right) 2-liter in the 2012 BMW 528i is a little monster. 240 ponies and 260 torques.
Ford just announced the 2.0L Turbo four in the Explorer will have 240hp / 270 lbft. More torque than their 3.5L V6 even.
lnlds
lnlds New Reader
7/28/11 9:16 p.m.
also the honda K doesn't really fit the bill because even though it gets decent gas mileage you it may get offset by the fact that they commonly burn oil
93EXCivic
93EXCivic SuperDork
7/28/11 9:38 p.m.
Fiat Twin cam.
MCarp22
MCarp22 HalfDork
7/29/11 12:13 a.m.
ProDarwin wrote: B) There is no reason that 6TH GEAR needs to have crazy acceleration. It spins at ~4200rpm at 80mph. Completely unnecessary. If I want to go faster, I can downshift.
There's probably a section at suzuka circuit or fuji speedway where 6th gear acceleration would be useful.
Travis_K
Travis_K SuperDork
7/29/11 12:48 a.m.
If you don't mind spending $20k on it, an older VW TDI can make some pretty good power and still get quite good mpg.
DaveEstey
DaveEstey HalfDork
7/29/11 4:16 a.m.
In reply to kb58:
I've never seen nor heard of that issue. The k series tranny in the rsx is frequently fine beyond 400 HP.
I know of a SM class crx in this area pushing 360 at the wheels with a stock k series transmission. Numerous seasons with no issues.
dculberson
dculberson HalfDork
7/29/11 8:24 a.m.
I feel the exact same way about the Miata. The 5-speed was understandable because it just needed to be wound out in 5th to really make the car fun to drive. But when they added a 6th gear and just tightened up the gear ratios instead of making it a taller 6th, they really missed an opportunity. Didn't make any sense to me. They would have achieved much better fuel economy with a taller 6th gear.
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
7/29/11 8:43 a.m.
The 6th gear actually revs higher in 6th than the 5spd in 5th. o_O
T.J.
T.J. SuperDork
7/29/11 8:48 a.m.
That is my biggest complaint about my Miata. It is nice to know that when I am cruising on the interstate in 6th at 65 mph that I am building boost already and that I can zip up to 80+ mph in no time without downshifting, but I'd rather have better fuel economy and an actual overdrive 6th.
ransom
ransom GRM+ Memberand HalfDork
7/29/11 8:55 a.m.
T.J. wrote: [glorious image removed for page height] BMW M10? Ok, not really, but the versions that found their way into Formula 1 sure put out a lot of power. The amount seems to grow with each passing year.
I've been tempted at times to just turbo the M10 in the 2002 instead of swapping out for something more modern. I know I could have substantial power, and there's a lot more room for plumbing and what have you with the SOHC head...
Space and reflected F1 glory vs an extra 30% power from stock compared to the M42... Pragmatism takes it.
oldeskewltoy
oldeskewltoy Reader
7/29/11 11:05 a.m.
T.J. wrote: That is my biggest complaint about my Miata. It is nice to know that when I am cruising on the interstate in 6th at 65 mph that I am building boost already and that I can zip up to 80+ mph in no time without downshifting, but I'd rather have better fuel economy and an actual overdrive 6th.
AZ6 6 speed gear ratios for all the companies and aftermarket(that I could find) available - Note the 6th gear in the S15 chassis
S15 6 spd 3.626 2.200 1.541 1.213 1.000 0.767
RX8 6 spd 3.760 2.269 1.645 1.187 1.000 0.843
Miata 6-spd 99- 3.760 2.269 1.645 1.257 1.000 0.843
SXE10 6 sp 3.874 2.175 1.484 1.223 1.000 0.869
TRD(33030-SE100) 3.106 2.175 1.585 1.223 1.000 0.869
NISMO 2.907 1.989 1.537 1.218 1.000 0.862
92CelicaHalfTrac
7/29/11 11:09 a.m.
The worst part about the MSM that TJ and i have is that it has that 6spd.... then a 4.10 rear end.
mndsm
mndsm SuperDork
7/29/11 11:18 a.m.
4g63. Look at it and it makes more power.
dculberson
dculberson HalfDork
7/29/11 12:02 p.m.
So can you take the final drive gears from the S15 AZ6 and pop them into the Miata AZ6?
imirk
imirk Reader
7/29/11 12:04 p.m.
mndsm wrote: 4g63. Look at it and it makes more power.
and then it makes even more on ethanol, probably 8 mpg though :P
awdxboost
awdxboost New Reader
7/29/11 12:18 p.m.
what about the ej20? decent power, good aftermarker support, reliable
imirk
imirk Reader
7/29/11 12:34 p.m.
awdxboost wrote: what about the ej20? decent power, good aftermarker support, reliable
it is H not I
1 2 3 4
KuEawy616pfCDjq4KuUhyqLVY1P39y7DUqjAELHm3aqGCF0ezC4ZKtmXrhLq9Nwn
