alex
alex HalfDork
6/5/09 12:10 p.m.
I need a borescope to get into a sparkplug hole on one of my motorcycles. Anybody have a recommendation for good/cheap/small? Has anyone used the Harbor Freight unit? The two models they sell at my local Home Despot don't have small enough lenses to fit a spark plug hole, unfortunately. For the record, I need something that will fit in a 12mm plug hole, at maximum, and ideally more like 10mm.
Trans_Maro
Trans_Maro Reader
6/5/09 1:34 p.m.
Milwaukee makes a reasonably priced unit. It fits into spark plug holes.
Shawn
alex
alex HalfDork
6/5/09 3:17 p.m.
Hmm. Do you happen to know if they make more than one model? Because the only one I saw was resolutely big on the lens end, and won't fit in a bike plug hole.
(I edited my above post for dimensions required.)
mrhappy
mrhappy Reader
9/11/10 5:46 p.m.
Did you ever find a cheap one that worked?
erohslc
erohslc Reader
9/11/10 6:28 p.m.
Here ya go:
http://www.usbfever.com/index_eproduct_view.php?products_id=965
At this price, everybody should have one of these in their toolbox...
Carter
unevolved
unevolved HalfDork
9/11/10 7:10 p.m.
erohslc wrote: Here ya go: http://www.usbfever.com/index_eproduct_view.php?products_id=965 At this price, everybody should have one of these in their toolbox... Carter
Bookmarked. I'm getting one of those when I get paid.
Hocrest
Hocrest Reader
9/12/10 6:20 a.m.
Can the escorts paddle a canoe?
moto_east
moto_east New Reader
9/12/10 8:48 a.m.
In reply to erohslc:
That one has a 6cm min focal distance--that means everything less than 2.5" away will be blurry. How bad it is hard to say, but for tight spaces that will limit it significantly. For general use I'm sure it is ok, but I'm not sure you'd see scoring on cylinder walls. Blown pistons though I'm sure :)
erohslc
erohslc Reader
9/12/10 3:35 p.m.
Oh well, BTTDB (Back To The Drawing Board). Seems like the need for a cheap WebCam on a stick with a short focal distance lens shouldn't be hard to fill. Anybody with pacific rim trading experience want to start up a company?
Carter
44Dwarf
44Dwarf HalfDork
9/12/10 5:34 p.m.
Check e-bay under medical equpiment.... bend over....
44
porksboy
porksboy Dork
9/12/10 6:16 p.m.
Secs say "Len’s Outer Diameter: 14mm " so wont fit OP's plug hole. I have one made by Rigid with a 17mm camera on the end. It does limit its use. I cant say how much it was, it was given to me with a broken elecrtical commection pin. A little safety wire as a replacement solved the problem.
erohslc
erohslc Reader
9/12/10 8:30 p.m.
Something like this? The tip is 8.2mm, and it come with a mirror (reflector tube) attachment (9.7mm dia) for looking sideways.
http://cgi.ebay.com/1-3MP-USB-digital-pen-microscope-camera-video-otoscope-/200517062461?pt=LH_DefaultDomain_0&hash=item2eafbf8f3d
The dental cameras look good, but none of them seem to specify the size of the probe.
It's a bit more $$, but gawd, those sample pictures are awesome.
Carter
foxtrapper
foxtrapper SuperDork
9/14/10 6:45 a.m.
I have the harbor freight one. Bought it for the Miata. Sadly, the head is too large to go into the spark plug hole. Same with the mirror on the tip. Good scope otherwise.
AREFucpmvtjs4ICYeg57LikGxITg4uFroqEdREflnlazcFsOxsXJaysmjE3fk2Yr
