In reply to Vigo (Forum Supporter) :
People also buy janky chinesium coilover suspension systems with no travel, no damping, and no isolation in the mounts, because they don't care at all about ride or handling as long as they can get the look just right.
I take a large grain of salt about any modifications people do without a clear goal for the outcome and/or an understanding of how the system they are changing works or is supposed to work.
Colder thermostats do help for some things, like drag racing your mostly stock 5.0 Mustang, because you're idling it down to a base level between 13 second bursts of wide open throttle, and the way their engines are laid out does reward colder coolant. Just because it works that way for them doesn't necessarily translate to other situations.
I wouldn't see a colder thermostat being useful on a Porsche unless there was a definite issue in the engine that can be traced to higher coolant temps, and it was one of the last steps in a multi-angled attack on the cooling system that started with better ducting to the radiator, larger radiator cores, reprogrammed fan control strategy, and/or water pumps with better flow characteristics at high RPM, because until you get the cooling system to the point where it is hovering around the thermostat opening temperature, the thermostat is going to open and stay open. (What good is a 160 'stat if the fans don't come on until 230?)
