93EXCivic
93EXCivic MegaDork
10/4/15 12:46 p.m.
So my 93 Civic was dead for a bit. It was the ECU. I got it up and running last beginning of last month with a used eBay ECU. I went to start it this morning and the car was dead again. Same symptoms.
What could be causing them to blow or am I just unlucky with a used part?
logdog
logdog GRM+ Memberand SuperDork
10/4/15 4:28 p.m.
Its possible you bought an ECU on its way out. It is 20+ years old. However if it is indeed a second bad ECU I would clean every single ground on the chassis and engine harness as maintenance. I would pull each bolt and run a thread chaser through the hole and one the bolt.
wlkelley3
wlkelley3 SuperDork
10/4/15 8:23 p.m.
That will keep you busy for a while. Keep you out of trouble w/swmbo. I picked up a OBD II/CAN code reader a couple weeks ago if that might help.
Sonic
Sonic SuperDork
10/4/15 8:33 p.m.
How about the main relay? Those go bad pretty frequently, can also kill the car.
impulsive
impulsive Reader
10/4/15 8:35 p.m.
leaking capacitor(s)?
bearmtnmartin
bearmtnmartin GRM+ Memberand Dork
10/4/15 9:03 p.m.
Distributors go bad on them. We went through three on my kids racecar.
93EXCivic
93EXCivic MegaDork
10/5/15 8:45 a.m.
Brand new distributor and main relay. Those were replaced before I got to the ECU.
93EXCivic
93EXCivic MegaDork
10/5/15 8:46 a.m.
impulsive wrote: leaking capacitor(s)?
I see that damage on the original but I don't see it on the second...
93EXCivic
93EXCivic MegaDork
10/5/15 8:47 a.m.
wlkelley3 wrote: That will keep you busy for a while. Keep you out of trouble w/swmbo. I picked up a OBD II/CAN code reader a couple weeks ago if that might help.
Car is ODBI.
The car was throwing a code before it died again though. I hadn't found anywhere that could check and didn't make it to the dealership to have them scan it.
93EXCivic
93EXCivic MegaDork
10/5/15 8:53 a.m.
logdog wrote: Its possible you bought an ECU on its way out. It is 20+ years old. However if it is indeed a second bad ECU I would clean every single ground on the chassis and engine harness as maintenance. I would pull each bolt and run a thread chaser through the hole and one the bolt.
Does anyone have a diagram of where any others would be or are these all of them?
bravenrace
bravenrace MegaDork
10/5/15 9:02 a.m.
In reply to 93EXCivic:
What ECU does it use? I have several and would give you one if it would work. But I think everything I have is 88-91 model year. In any case, let me know and I'll check.
93EXCivic
93EXCivic MegaDork
10/5/15 9:20 a.m.
bravenrace wrote: In reply to 93EXCivic: What ECU does it use? I have several and would give you one if it would work. But I think everything I have is 88-91 model year. In any case, let me know and I'll check.
P28
I am ordering replacement caps today for both and the electrical engineer at work can replace them.
clutchsmoke
clutchsmoke SuperDork
10/5/15 11:59 a.m.
This sounds like the best plan. Should hopefully fix your issue.
logdog
10/5/15 12:28 p.m.
Those should be all of the ones for the engine harness but there are more on the dash/chassis harnesses (or is it a "flock of harness" to describe more than one?). I have a factory manual but it is packed up right now. Maybe somebody else can help. I believe there is one or two in the vicinity of the main relay under the left side of the dash.
93EXCivic
93EXCivic MegaDork
10/5/15 12:46 p.m.
http://techauto.awardspace.com/ecu.html
Someone pointed me to this. So I am going to run through these checks with my replacement ECU as I see no burnt traces on that one's PCB unlike the old one.
BKZE44NTBa3pgufkSBS58byNSbyQSJcYxRjKEncNqXPipP8v8fF2B8lPVHaUARag
