flexi
flexi Reader
9/24/16 2:48 p.m.
Any tips to remove RTV from surfaces and inside threads? Attempting to seal up the bottom end of a miata block. (RMS, oil pump, oil pan, etc.) Is there a solvent that works? Reluctant to use HF taps since they don't seem to use the same standards as everyone else.
fasted58
fasted58 UltimaDork
9/24/16 3:29 p.m.
besides a good tap, a rifle bore brush, compressed air and brake clean or all of the above.
flexi
flexi Reader
9/24/16 3:33 p.m.
Good idea on the bore brush! Wasn't sure what solvent would work. I'll try the brake kleen, and the bore brush. Thanks.
44Dwarf
44Dwarf UltraDork
9/24/16 8:45 p.m.
mineral spirits will soften and swell RTV. then a rifle bush will clean the hole.
curtis73
9/25/16 8:06 p.m.
I use a thread chaser and air gun. Don't use a tap; its a different animal. It will cut more metal. Just use a chaser.
Knurled
9/26/16 6:14 a.m.
Razor blade to get the thick stuff, kerosene or carb cleaner and a wire brush to get the major bits off of the sealing surfaces and carb cleaner and a Scotch-Brite pad to get it really clean and carb or brake cleaner on a paper towel to get it clean enough to seal.
I never really worry about the threads.
motomoron
motomoron SuperDork
9/27/16 2:22 p.m.
Cured RTV silicone isn't actually dissolved by much. Maybe methylene chloride, Permatex and Loctite both sell Silicone solvents, but they're way toxic and expensive.
I use a variety of scrapers, steel and brass scratch brushes, and chasers. I find the stiffer, straighter and sharper the scraper, the less likely it is to put scratches in the sealing surface. So I keep a high speed steel lathe cut-off blade around. It works great.
Knurled
9/27/16 4:50 p.m.
Yah, dissolving the sealant isn't the goal so much as separating it from the metal. This is aided by a solvent and mechanical removal (scrapers/wire brushes/Scotch-Brite pads, the ones you hold in your hand not the Rolocs!)
JclNtTAFNmQvou9fvLwdp8xRVB0kWAFEGBy4aYcs0yO5n2EKgrNpV93BldjVSV8Q
