belteshazzar
belteshazzar UltraDork
9/6/12 4:27 p.m.
my '94 Miata has 102k miles. Only modifications are timing bumped to 14 degrees, and a borla exhaust.
102hp and 98tq, very consistently over 17 pulls.
typical?
also; i started the run at 3000rpm. the a/f ratio would ripple a little and then settle down by 4000rpm. unfortunately it settled very rich. is that typical too?
SpeedTheory
SpeedTheory GRM+ Memberand Reader
9/6/12 4:32 p.m.
Dynojet? If those are Dyno Dynamics/Mustang, I'll gladly trade. If Dynojet, we're both not in the best shape, see my thread today. Stock timing and a Goodwin exhaust.
9/6/12 4:43 p.m.
That's right about what we used to see on our Dynojet, including the A/F fluctuations from the closed loop dithering.
ProDarwin
ProDarwin SuperDork
9/6/12 4:48 p.m.
Keith Tanner wrote: That's right about what we used to see on our Dynojet, including the A/F fluctuations from the closed loop dithering.
Corrected, or no? Aren't you at 5000+ feet?
9/6/12 4:52 p.m.
Corrected, which is usually pretty darn accurate for naturally aspirated cars. Unless you have a climate controlled dyno room, always use correction.
ProDarwin
ProDarwin SuperDork
9/6/12 5:02 p.m.
Out of curiosity, what are the uncorrected numbers you see Keith?
9/6/12 5:33 p.m.
Depends on the temperature, air pressure and humidity. Correction factors up here range from 16-21%.
belteshazzar
9/6/12 6:03 p.m.
this was on a dynojet.
so keith (or anybody), is there room for meaningful improvement simply by retuning the air-fuel ratio? 11:1 seems like it's leaving something on the table.
9/6/12 6:26 p.m.
The Spec Miata guys seem to do pretty well by dinking around with fuel pressure. I don't know how it would work out off the racetrack, though. Naturally aspirated engines have a pretty big sweet spot to play with.
o5mwj0UZuIudQ3Bh19n0ZE3triLbDbwdk9SeUkdGYUrl346WlIHjaHX0Wc51gbnd
