tuna55
tuna55 UltimaDork
5/30/14 6:58 a.m.
Breaking out from the truck thread. I am need of a somewhat flexible rubber section for my fuel filler to slip over 2 1/4" exhaust tubing. Something on the order of a foot long. What I have found thus far is crappy clear tubing which is probably far too weak, or super expensive Goodyear or Dayco stuff mail order for $30 per foot. Does anyone here have any leads?
stafford1500
stafford1500 GRM+ Memberand Reader
5/30/14 7:07 a.m.
I was able to source a 1 foot long section of fuel rated hose, with wire reinforcement from McMaster. I needed about 4 inches of the material. I will check to see if it is 2.25 ID. If it is the rest can be yours...
solfly
solfly Reader
5/30/14 7:18 a.m.
napa has gates stuff. about 30 a foot though. part #1055
fasted58
fasted58 PowerDork
5/30/14 7:23 a.m.
I went through that when I was installing a Suburban tank in a PU chassis.
Went thru the PnP. Our local yard pulls all the tanks and piles 'em up, most w/ hoses attached. No need tramping all over, they were all in one place.
Javelin
5/30/14 7:23 a.m.
I'll check the scraps at work. We sell the Gates stuff every day.
whenry
whenry New Reader
5/30/14 7:30 a.m.
I had to do the same thing with my '96 4runner when it started leaking. I found a universal hose at NAPA for $18 that just need a little trimming. I did put two hose clamps on the "pressure" end at the fuel tank just to feel safer with it.
tuna55
tuna55 UltimaDork
6/9/14 10:04 p.m.
Finally got the 1055 from NAPA. Not too bad of a price at just under $23. Now... I need it to bend just a bit, and it won't. Does anyone sell just the wire coil spring for the ID of a 2.25" hose?
tuna55
tuna55 UltimaDork
6/11/14 5:06 a.m.
No thoughts, folks?
Dusterbd13
Dusterbd13 Dork
6/11/14 6:53 a.m.
Mopar lower radiator hose spring should work. If I get to the salvage yard this weekend ill snag you one.
tuna55
tuna55 UltimaDork
6/11/14 7:01 a.m.
I had a thought that may dissuade you, Michael, I really ought to get something stainless...
Dusterbd13
Dusterbd13 Dork
6/11/14 7:34 a.m.
I've never seen them rust, but I don't think they are stainless.
tuna55
tuna55 UltimaDork
6/11/14 7:47 a.m.
Dusterbd13 wrote: I've never seen them rust, but I don't think they are stainless.
They wouldn't rust when emerged in coolant, but they would definitely rust when gas flows over them every week or two and get dry the rest of the time.
tuna55
tuna55 UltimaDork
6/13/14 7:39 a.m.
So it's either $45 to buy one stainless steel spring, or I redesign my fuel filler... again. I essentially need an S bend made out of something-pliable-and-fuel-safe, 2.25" ID. Ideas? Anything less than $45 is a winner.
Ian F
Ian F UltimaDork
6/13/14 9:54 a.m.
Steel pipe s-bend with rubber connectors at each end?
tuna55
tuna55 UltimaDork
6/13/14 11:08 a.m.
I can't really do that because I need the support of a one piece steel section (meaning, no rubber between the tank and the neck joints).
I actually think I may have a better idea: Remove the bed to install/remove the fuel filler neck.
qEOTmFIofIHTyskQfLVr3QKl7lNSFCIErJkbFU8vj2tO2vfCDOoRRgX7XNSPdlWc
