I've been chasing a dropping / inadequate fuel supply problem for a week or so and I'm completly out of ideas at this point. As I gradually deconstructed the whole fuel system to try and isolate the issue, it seemed like I was getting inconsistent results. To the point that, having not written down the test setup and results, I started questioning what I had done on previous tests.
Fast forward to today, and I started the day with a new fuel pump. But even this has devolved to where I am now. My test setup is: 5gal bucket of diesel -> hose -> strainer/pre-filter -> fuel pump -> hose -> "calibrated" bucket (marked every 1/4 gallon). In addition, I have a voltmeter on the terminals of the pump, and a clamp-style ammeter on the 12V wire to the pump.
When I jump the fuel pump relay, it initially seems to be flowing great. In the neighborhood of 1gpm, which is what I'm expecting. Voltage is solid at 12V +/- 0.1V. Ammeter shows about 4.5A. But over the course of 1-2 minutes of continuous running, the flow gradually diminishes, while the amps gradually drops to more like 2A. Still 12V though. If I stop, wait like 5 minutes, and try again it does pretty much the same thing. If I wait like 30 seconds it starts off stronger, but not what looks like "full flow". In my 30 sec rest example, the current starts off on the 2nd round at about 3.5A instead of 4.5A and then gradually starts dropping.
Under a normal setup, I could imagine heat causing this or the tank not venting adequately, creating a vacuum situation in the tank. But neither of those make any sense in my dumbed-down test setup.
So I'm completely flummoxed. Any ideas, either for what's happening, or for another test? I don't want to put the whole thing back together until I have some confidence it's working right. Which it clearly isn't now!
