NOHOME
NOHOME UltimaDork
10/19/18 6:24 p.m.
This thing have an IAC valve?  They gum up and might prevent a start.
Be funny if you had two things wrong that canceled each other. EGR and IAC
Pete Gossett
10/28/18 1:30 p.m.
I had a few minutes today to troubleshoot. There is zero fuel from either injector during cranking, despite having fuel pressure at the TB and some voltage/pulsing at the injectors.
I’m seriously considering a carb swap.
Stampie
Stampie GRM+ Memberand UberDork
10/28/18 3:01 p.m.
In reply to Pete Gossett :
Carb swap is like 99% of the work of an LS swap.  You know from what I hear on the internet.
Pete Gossett
10/28/18 3:46 p.m.
In reply to Stampie :
But I’ve already carb-swapped one sbc, so I pretty much know what I’m up against.
SkinnyG
SkinnyG UltraDork
10/28/18 3:56 p.m.
If you touched a 9V to the injector briefly, would it click?
Pete Gossett
10/28/18 6:27 p.m.
In reply to SkinnyG :
I’ve not tried that, but I have new 9v I can try it with.
Pete Gossett
11/9/18 10:37 a.m.
To give this thread some closure & hopefully help someone else in the future, I receive a message & pic from the new owner yesterday. He found the driver’s side injector was shorted, causing that fuse to repeatedly blow, then digging further found a burnt diode on the ECM.
K6X9439tfrcJy7H4eMrmVePvQbRngGpu33PekLGnbaWhqwlqBbdMoI5EoVzdmJ1V
