racer_ace
racer_ace New Reader
10/9/08 8:11 p.m.
It looks like the Throttle Position Sensor in my 1988 RX-7 may be the cause of my high idle problem. The resistance accross the TPS should be 5k ohm +/-1 at full throttle and 1k ohm at idle. Mine is reading 4.9 at full throttle (OK) but 2.4 at idle (no good). The manual says you need a special diagnostic tool to adjust the TPS. Is there any way I can adjust it myself without the diagnositc tool? ...Or do I need to take the car to a Mazda dealer?
bruceman
bruceman New Reader
10/9/08 8:58 p.m.
http://www.rotorwiki.com/index.php/TPS_Adjustment
racer_ace
10/9/08 10:41 p.m.
Thanks Bruceman. A couple of LEDs and some spade connectors...I can handle that!
Osterkraut
Osterkraut Reader
10/9/08 10:51 p.m.
Warning: chances are you'll never get it fixed properly. They're fickle beasties.
noisycricket
noisycricket New Reader
10/10/08 6:44 p.m.
TPS is mainly important for idle concerns. If it has to be off somewhere, then let it be off at the top end.
3iUjj6LaDMv4lJdKfOu12JNQBmSohVHh3ukFhbdCTWrY23VAIGyvzJiTH3acD2Fp
