grover
grover GRM+ Memberand Dork
5/6/22 9:25 p.m.
I own a 2008 sequoia that has, what I would call- not amazingly clear headlights.  To me, not much makes a car look unkept more than hazed headlights, and it really brightens up the front end of an older car to have clear lenses.  To that end, I've been wanting to do mine for a while.
Project Farm reviewed headlight restoration kits some time back and recommended the Sylvania, so that is what I planned on using.  My son and I visited 3 different parts stores on Saturday that all claimed to have the kit in stock, and none did- so I was forced to use amazon after spending a good bit of gas to buy in person.
The kit arrived Tuesday and after reading the directions first, and probably one of the few times in my life that I've done so, I realized that the car would have to sit for 6 hours after doing the work, so I had to wait until after my run tonight to have the garage and the time to do it.
The kit is different than others that I have used in the past.  It has the typical sandpaper (800, 1000, 2000) but it also has an "activation" spray a polishing compound and finally a uv sealer.  Really, it's got way more than just a powerball and some compound.  It should also last quite a bit longer than your deet bug spray hack.
I started by cleaning the lens and then applying the activator.  No photos before unfortunately, but this is after the activator.
You'll notice the lens is not great, but the fog light is really poor as well. On to the 800...
proper haze there on the fog and lens....now on to 1000
and 2000
now on to the finish..
but remember that we had to use a compounding formula after this and the activator again.
and let's check out the fog light, it's on the other side- but they started out the same.
Fuzzy photograph, but it was dark.  Honestly, it looks amazing.
All in the all the kit was pretty easy to use and took me right about an hour.  I have large headlights, and the fog lights were a bit of a pain with location.  I used mostly my thumb to add pressure to the sandpaper for them.
The UV seal is really interesting.  I had read someone else on here had wished they had used more, so I did each lens several times.  It honestly feels a lot like a shellac with a uv coat, I can't confirm that's what it is, but I've got a hunch- Frenchy will be thrilled.
I'd give the kit 2 solid thumbs up.  It does require a legitimate dose of elbow grease, but you also don't want to do this every 6 months and it's well within the "worth the effort" range of activity.  I'll post another photo tomorrow in the light.
Javelin
5/6/22 9:46 p.m.
In reply to grover :
When that UV stuff dries it looks soooo nice and new. I love the Sylvania kit.
grover
5/6/22 11:36 p.m.
In reply to Javelin :
it's hard not to take it out check out how they work.
Caprigrip
Caprigrip Reader
5/7/22 1:42 a.m.
I love the Sylvania kit.  I had fun doing three cars last week - my mother in laws, my RX8 and a charity car I cleared up. About an hours work per car but results are amazing.
Caprigrip
Caprigrip Reader
5/7/22 1:43 a.m.
Caprigrip
Caprigrip Reader
5/7/22 1:43 a.m.
grover
5/7/22 9:53 p.m.
Those are amazing results.
Now that I have been able to look more at mine in the sun, and drive at night I have some observations.
-Clean the tar out of the lenses before the last step.  I can see that part of the passenger side wasn't super clean on the side and now it's sealed in.
-Nighttime visibility is massively improved.  Well worth the effort.
-I could have spent a little more time and effort I think.  I still have some haze, but again, this is a vehicle from 2008. I'm not sure that it was crystal clear when brand new.
Photo from this morning.
XLR99 (Forum Supporter)
XLR99 (Forum Supporter) GRM+ Memberand Dork
5/8/22 2:37 p.m.
Ugh, wish i saw this a couple daya ago...
I got a Cerakote ceramic kit for my RSX. It comes with pre-wipes, 2000 and 3000 sanding discs, and the ceramic wipes as final step.  It went on fine, looked much better afterwards, and all was well. About 2 hours later I walked by the nose od tye car and must have brushed the headlight with my shorts or something, leaving a big giant smear.  Berkley
Not a great pic, but its just above the bulb about 4" long.  Apparently it needs more time to cure completely than I thought.
I assume at this point I have to let it cure and then sand down and start over again?  Am i locked into using the cerakote stuff again?
grover
5/8/22 11:37 p.m.
Wow, that is super annoying it's not scratched- but I wouldn't just throw some solvent on it to get it to accept new coating. Sounds like you'll have to strip the coating mechanically or chemically and recoat. I'm sorry- that's a bummer.
5/9/22 8:20 a.m.
Yeah, the other side looks great. I did a bit of DuckDuckGo fu while watching F1, and cerakote recommends sanding down and recoating.  I think I'll go with the Sylvania kit for my daughter's car though. If nothing else it will give a good comparison of durability
i haven't used the Sylvania kit yet, but i've had great results with the RustOleum Wipe New kit.  It seems to hold up for about 18 months, then deteriorates noticeably over the next 6 months.
engiekev
engiekev HalfDork
5/9/22 9:18 a.m.
I took the lazy route and used PlastX, admittedly will not work as well as sanding method and without any UV sealing it will need to be performed again and again. But for a quick fix they turned out great!  I'll apply some sealer wax and report back when they haze up again.
Amazon.com: Meguiar's G12310 PlastX Clear Plastic Cleaner & Polish, 10  Fluid Ounces : Everything Else
Left is untouched, right is PlastX.  Ignore the vinyl stripe test strips.
porschenut
porschenut HalfDork
5/9/22 9:56 a.m.
I did the wet sanding thing once and now just use a plastic cleaning or polishing compound on a foam disc every 6 months.  The sealer is a 303 protectant that works on any plastic in the sun.  Headlights look great.
Caprigrip
Caprigrip Reader
5/15/22 12:16 a.m.
did the sister in laws Sequioa today using the Sylvania kit.  Love this kit.
5/15/22 11:28 a.m.
Y'all got any of them links to the Sylvania kit? Asking for a friend.
Caprigrip
Caprigrip Reader
5/15/22 12:58 p.m.
https://www.amazon.com/SYLVANIA-Headlight-Restoration-Headlights-Protection/dp/B01KIVYE6G/ref=sxts_rp_s_a1_0?crid=1SC1AT844YSDV&cv_ct_cx=sylvania+headlight+restoration+kit&keywords=sylvania+headlight+restoration+kit&pd_rd_i=B01KIVYE6G&pd_rd_r=dfc207c5-f3af-4895-ab4f-4f32f1b98779&pd_rd_w=Ykdbv&pd_rd_wg=BPUzS&pf_rd_p=fe543514-8042-43ea-9a7d-16ca15182bc8&pf_rd_r=S66DNWR784Y75YRDG5KZ&psc=1&qid=1652633849&sprefix=sylvani%2Caps%2C464&sr=1-1-ea136695-3596-4534-80e7-1570345d02b9
grover
5/16/22 1:07 p.m.
Amazon seems to be the place to go.  none of my local shops had it.
QkZvQ9rz8J3RXydqOFHqso6QXWRlYvUJESvRfFqUilaVdPSZ3xAfD3VjKVi0oM2p
