daeman
daeman HalfDork
10/26/16 4:22 p.m.
With the f2t, the top Half of the inlet Mani unbolts. Making a plenum is probably less work than the flip.
Otherwise I've got a tbi manifold that will fit the standard b2000 and b2200 8v heads if that helps?
Another thing with the f2t to consider is that the turbo faces the wrong way for rwd so makes plumbing a bit of pain.
The standard Fe and f2 are both fairly boost friendly in terms of compression, about 8.6:1. Sure they only have 8 valves, but the exhaust valve in the 8v heads is larger than the 12v heads. The single inlet vs twin inlet Valve is only about 10% smaller im terms of surface area.
captdownshift
captdownshift GRM+ Memberand UberDork
10/26/16 5:48 p.m.
Skip any diy and purchase a heavily depreciated AMG benz.
moparman76_69
moparman76_69 UltraDork
10/26/16 6:49 p.m.
1G boxy Dakota, 2.4 engine, Jeep Wrangler bellhousing, Solstice MA5 5 speed. You should be able to JY mix and match an intake and buy a turbo header that will help with turbo placement.
G_Body_Man
G_Body_Man SuperDork
10/26/16 7:13 p.m.
7MGTE Mk3 Supra Turbo. Buy a running car, then immediately do the timing belt and water pump, as well as throw on a new head gasket and install ARP head studs with everything torqued down to the correct spec of 75 ft-lbs (as opposed to the improper factory spec of 56 ft-lbs). Enjoy a cheap, reliable, smooth turbo car for years to come.
Chadeux
Chadeux HalfDork
10/26/16 7:23 p.m.
In reply to moparman76_69:
I think at some point I want to do this, but replace Dakota with AMC Spirit.
yupididit
yupididit HalfDork
10/26/16 7:34 p.m.
Just going to throw a curveball oddball here:
MPI or jz swapped starion/conquest
Chadeux
Chadeux HalfDork
10/26/16 7:40 p.m.
That reminds me of another idea.
https://www.youtube.com/embed/0rRDuuuYGQY
Turbo 4g powered Mighty Max.
turtl631
turtl631 Reader
10/27/16 10:45 a.m.
pres589 wrote: In reply to turtl631: What about turbocharging the KA24 that is already in the 240SX, what kind of hp and torque numbers are relatively easy there?
Around 300/300 is doable and safe with a good tune. The KA is a little more fragile under boost than the JDM swap motors that came turbo, but they can do well with appropriate parts. I think a lot that blow up are broke kids throwing the bare minimum at the car. I dynoed 350 whp with a stock KA that did road trips and track days.
I think a smart way to go is with SR20 style parts. If you run a manifold that positions the turbo same as on stock SR20, you can use off the shelf exhaust and intercooler plumbing. A stock T28 turbo from an S14 or S15 Silvia will do 280-300 whp with quick spool, or you can pick up a used Garrett GT2871,etc. You just want to avoid cheap shiny eBay manifolds that crack. This manifold would be great: Expreme!
Ka-t.org is a good resource.
engiekev
engiekev New Reader
10/27/16 11:56 a.m.
Ecotec swap . Cheap and plentiful, unique as they aren't a lot of RWD swapped ecotecs out there. Plenty of power potential, look at what GM did with them drag racing back in the NOPI days.
http://www.speedhunters.com/2016/09/datsun-time-attacker-gm-ecotec-power/
http://www.superstreetonline.com/how-to/engine/turp-0203-gm-racing-ecotec-engine/
SAE paper here if you have the means of accessing: http://papers.sae.org/2002-01-3354/
Buy a salvaged sky or solstace and swap it all over for easiest method?
https://www.copart.com/lot/35332696/?resultIndex=7&totalRecords=10&backTo=%2FlotSearchResults%2F%3Ffree%3Dtrue&query=saturn%20sky&query=saturn%20sky&displayStr=Search%20Results&viewedLot=35332696
engiekev
engiekev New Reader
10/27/16 12:11 p.m.
4G63 are very easy to RWD swap now. Easy 300-400 HP on a stock long block, cheap to build up if you want, plentiful parts, basically the small block of the import world. A lot easier to find parts for than a SR20DET, as they sold a boat load of DSMs here (talon eclipse laser). Engine management is easy and cheap too, DSMLink software allows you to run a stock ECU with a chip and avoid having to tune a stand alone system.
Lots of resources here:
http://projectzerog.com/
A shop out of Toledo makes custom bell housings that bolt directly to 4G63s for a LOT of transmissions:
http://www.billsautofab.com/
Chadeux wrote: That reminds me of another idea. Turbo 4g powered Mighty Max.
turtl631
turtl631 Reader
10/27/16 3:58 p.m.
The 4G63 is an amazing motor, but sr20det parts aren't hard to get your paws on. There's little that's unique to the JDM engines and plenty of places to get it. That said, the SR appeals mostly as an easy swap into the 240SX with bolt on hop up parts that fit the engine and the chassis. You don't have to be a fab master to build a fast fun car.
engiekev
engiekev New Reader
10/30/16 10:31 a.m.
Its certainly cheaper to find a full 4G63 longblock or engine I would say, unless SR20 prices are past the drift tax by now?
turtl631 wrote: The 4G63 is an amazing motor, but sr20det parts aren't hard to get your paws on. There's little that's unique to the JDM engines and plenty of places to get it. That said, the SR appeals mostly as an easy swap into the 240SX with bolt on hop up parts that fit the engine and the chassis. You don't have to be a fab master to build a fast fun car.
turtl631
turtl631 Reader
10/30/16 4:38 p.m.
Yes, I'm sure 4G63 is cheaper. The 240SX is just a nice chassis with a ton of parts availability if you want a relatively light RWD car. The SR20 is an easy swap.
yupididit
yupididit HalfDork
10/30/16 5:08 p.m.
A rwd 4g setup will cost you what sr20 are going for. It not more.
RyanW
RyanW New Reader
10/30/16 5:10 p.m.
4g63 swap in anything. Using that motor + a trans that can actually handle power, must be a magnificent feeling.
400hp on a stock block is nothing for one.
One day I'll have something RWD + 4g63. For now, I'll stick with my 4 AWD 4g63s
Honestly, If you're trying to swap something, I'd go Turbo LS, or just find something LS powered already.
yupididit
yupididit HalfDork
10/30/16 5:40 p.m.
You'll need an r154 or t56 for a 4g. You can buy a sr20 with everything for the cost of going with a r154/t56+clutch+adapter.
Bill Hincher makes the kits though.
TIGMOTORSPORTS
TIGMOTORSPORTS HalfDork
10/31/16 4:54 a.m.
In reply to penultimeta:
I would second the vote for turbo 3.8 GM Fbody
Opti
Opti HalfDork
10/31/16 2:38 p.m.
Not interested in a 6 cyl turbo fbody. Ive had a decent fbody, want to change it up.
yupididit
yupididit HalfDork
10/31/16 6:46 p.m.
What's your budget?
Opti
Opti HalfDork
10/31/16 7:19 p.m.
Hadnt though about it maybe 5 ot 6k for the big main stuff. The sorting and small stuff i could do later
chiodos
chiodos Dork
10/31/16 9:44 p.m.
In reply to Opti:
So i read this thread and thought on it for about an hour and heres the best ive got.
If it were me id get a mustang of sorts, hell they come in all shapes and sizes just pick one that suits your fancy and depending on the situation build or buy a turbo kit to make that mustang quick. For 5-6k max budget I think thats the highest smiles per dollar ratio yet still have cheap parts and not suck totally while not in boost
Petrolburner
Petrolburner Dork
10/31/16 11:20 p.m.
I was really hoping this was going to be a thread where you asked us to talk you into turbocharging your C5.
Chadeux
Chadeux HalfDork
11/1/16 12:36 a.m.
What about the cheapest g-body you can get, then put a turbocharged 3800 in it. Sort of like a trailer park special Grand National.
classicJackets
classicJackets Reader
11/1/16 7:05 a.m.
If we're talking about going KA-T, let's not forget the kA came in hardbody pickups for several years (in SOHC form but still) and thats very much an option as well
Opti
Opti HalfDork
11/1/16 8:29 a.m.
chiodos wrote: In reply to Opti: So i read this thread and thought on it for about an hour and heres the best ive got. If it were me id get a mustang of sorts, hell they come in all shapes and sizes just pick one that suits your fancy and depending on the situation build or buy a turbo kit to make that mustang quick. For 5-6k max budget I think thats the highest smiles per dollar ratio yet still have cheap parts and not suck totally while not in boost
I originally wanted to do the sn95 5.0 or miata. I was wondering if I was overlooking anything
p4NYf9pQ0EIbcvXa5ArzlpqiCwgFAzkbWBfVyhVWXbWe5Wznpe9Yvy8LRfWrDCEi
