Craigorypeck
Craigorypeck Reader
8/3/18 3:30 p.m.
Playing around with injection timing on my ms3.
It's set at 360 from factory.
What gains can be had?
I can see change at idle as that's easy to monitor but should I be aiming for more rpm.. More vacuum or leaner/richer afr?
Matthew Kennedy
Matthew Kennedy GRM+ Memberand Reader
8/3/18 3:38 p.m.
On a port injected engine there isn't much improvement to be had outside of improving efficiency, emissions and idle quality.  As a rule of thumb, finishing the injection somewhere near the time that the intake valve starts to open is reasonable.
jimbbski
jimbbski Dork
8/3/18 6:06 p.m.
What he said.  As engine load goes up and fuel needs increase the injector duty cycle increases. On some engines at full throttle that may mean near 100%!
Craigorypeck
Craigorypeck Reader
8/4/18 11:56 p.m.
I wacked 400 in across the entire injector timing table and it pulled fuel pretty much everywhere.
Red areas are where it pulled fuel.
8/5/18 1:37 p.m.
I use an injector timing table based on this one with 4 squirts per cycle:
It works OK. No major difference in AFRs from the stock setting of 360deg everywhere.
Matthew Kennedy
8/5/18 8:39 p.m.
In reply to GameboyRMH :
With 4 squirts per cycle, the injection timing is doing almost nothing anyway.
nSm7UBgsvQdg5GVmKGT4EZWfzcYJ01P3coX0duHFFDAm0UrUmwWtYhnDxvVhJSna
