Hasbro, I LIKE that Exxie!
I've had 2, a '79 carbed 1.5 and an '81 FI 1.5. I have the most seat time in the '79 and I loved it. They are probably the most fun handling car ever built and that is saying a lot. The interior actually fits a big guy pretty well.
Rigid chassis (if not rusty). The body is overbuilt and does not flex much at all, very well designed. Too bad the steel wasn't as good as the chassis engineering.
Simple suspension (how about no swaybars???) that responds well to the usual tuning, the motors are actually pretty reliable. The 1.3's (pre- '79) were interference motors, the 1.5's are freewheel. Neither engine makes a lot of power and from what I understand do not accept boost very well without majorly expensive modifications (never tried it myself).
The 4 speed trannys are tough as nails, the 5 speeds not so much. The 5 speeds are hard on reverse idlers, if you ever have one apart you'll see why; there is no support for the reverse idler shaft. Stick it in reverse and the idler shaft will try to bend away from the cluster, this eventually cracks the case, then the idler makes poor contact and good bye idler gear. A new idler is a Band Aid, the case crack is the real culprit. Strada tranny guts will go in an X 1/9 case and they don't command nearly the premium that Exxie boxes do.
Weird 4x98 mm wheel bolt circle, there are 'wobble bolts' which allow using common 4x100 mm wheels. Brakes are great, with one problem: the calipers are for whatever reason VERY prone to corrosion, this is worst on the rear. The master cylinder is in a bitch of a spot, too.
Typical Italian electrics of the era; way too many wires, a whole bunch of relays for no particularly good reason, corrosion prone. The fuse/relay box is under the glove box, lower that puppy and you won't believe what you see. Strangely, neither of mine had any switch issues.
If you have to refill the cooling system, there is a bleed screw on top of the radiator on the right side. It's, IIRC, a 7mm Allen. It's also unviewable. You have to feel around till you find a hole, then stick the Allen wrench through that hole and looesn the bleed screw. Lots of cussing goes with that one.
The aforementioned ignition module is perched at the bottom of the right side 'sail'. There's a drain under it which can easily get clogged with leaves etc and each time it rains the ignition module goes swimming. It's easy enough to convert it to a GM HEI. The really dumb thing: the FI cars have the ECM inside the spare tire well which is inside the car, well protected from the weather. Why didn't FIAT do the same with the ignition module?
Window regulators are done with a 1/8" cable going every which way. Must be seen to be believed.
