Is it just about load rating? I'm thinking of replacing the Dueller Revos on the tow rig, and noticed they have a Revo LT-rated as well as the non-LT ones I have on there now, in the same size. The higher load rating is a plus, but is there any other difference (like rubber compound)? Seems like the LT version is cheaper but has a higher treadwear rating. What's the downside?
The LT version likely has somewhat deeper tread. It'll have beefier sidewalls and probably feel less flexy. They will be heavier though.
Opti
HalfDork
1/9/18 9:59 p.m.
I almost always recommend the P rated tires if thats what the oem recommended, lighter, have a mileage warranty (many times the same tire in an Lt looses its mileage warranty), ride better, have enough load capacity for the oe tow rating, and are generally cheaper.
Its a little different with hardcore off roaders, or when for some reason the lts are cheaper.
amerson
New Reader
3/12/18 9:56 p.m.
LT tires have less flex in the sidewall and slightly rougher ride, though they are more capable for hauling and towing than P-rated ones. So if you are hauling heavy loads, LT is a better choice. I currently run Destination A/T LT275/65R18 on my truck. These Firestone tires are great. Have good road manners and reliable traction.
Hal
UltraDork
3/13/18 5:55 p.m.
This^^ Plus the ride will be a bit more harsh. If the tow-pig is also SWMBO's DD it might not be a good idea.
I put a Michelin LT tire on my 4Runner and it now rides rough as hell. I regret getting them. My driving is mostly highway and rarely towing.
I was in charge of the production of both LT and non-LT tire production tire specifications a year ago. The main differences:
- LT tires get a higher load rating
- They get this higher rating because they are designed to hold more air pressure, which allows them to support more load.
- In order to hold more air pressure they have stronger components within the tire and typically more of them. The carcass cords are stronger or more tightly spaced. Sometimes there is a third body ply added. The steel belts below the tread are stronger and sometimes wider.
- The tread depth and compounds are sometimes different as well to account for the different uses.
- This all leads to what has been said above: LT versions are typically stronger, heavier, stiffer, and rougher riding at the same load. But they are great at doing what they were designed for: supporting heavy loads.
The higher treadwear rating on the tires you are looking at may be because the LT versions are only in larger sizes. It's easier to get a high rating with large, wide tires. I'd suggest you stay with the passenger version and leave the LT tires for the 3/4 and 1-ton trucks.
