EvanR
EvanR New Reader
5/18/10 3:44 a.m.
I thought I did all my homework before buying some CL MINI Cooper wheels and tires for my '05 Scion xB.
Bolt circle, offset... everything was right. I even posted here and found another member here who'd done the swap successfully.
Then I went to mount them. Never once did I think about wheel thickness at the lugs.
Common wisdom says the lugs should go completely through the nuts. Mine do not, by 1-2 threads. That'd be 1.5-3mm @ 1.5 thread pitch.
Now... we're talking about a street-driven car. While the xB is a decent handler, I'm not racing nor taking corners at high speeds.
What say the wisdom of the board? Am I in decent enough shape, or should I worry?
Thanks, Evan
AngryCorvair
AngryCorvair GRM+ Memberand SuperDork
5/18/10 5:48 a.m.
i think it doesn't matter if the lug goes all the way through the nut, i think what matters is how many threads on the lug are engaged by the nut. get a MINI nut and a scion nut and compare them side by side. perhaps the scion nut is taller?
44Dwarf
44Dwarf HalfDork
5/18/10 6:14 a.m.
Mil'spec on all hardwear used to be bolt dia plus 2 threads. I try to use that on all my stuff too, how ever I've run in to things like this myself if i use a normal lug nug nut on my race car i only have two threads showing but if i use the double sided lug (taper on both side no messing around on quick pit stops) I'm short but a ways. Tech guy noted it and made me show him with single tapper nut. I need to find a longer stud just to keep my "visual all is good walk around pre race inspection" Dorman has a nice PDF that give Kurl size, thread size, thread pitch, over all lenght etc. I've got the link somewhere...
FOUND IT! https://www.dormanproducts.com/catalog/hardware2006/001-005AlphabeticalIndex.pdf
44
DeadSkunk
DeadSkunk Reader
5/18/10 8:37 a.m.
I've run my MINI wheels on my wife's Xb and never noticed that. I'll have to check more carefully the next time I fit them.
afGY4GnR4MhT05do0LRr8Fye5QocRF60i4A2h9Xl19rCerfXP7bDFq6bzqs5sXA4
