Tommy Suddard
Tommy Suddard GRM+ Member
7/20/08 8:11 a.m.
The odometer on my e30 doesn't work, and I have heard that there are gears in there that melt in the heat. Does anybody know how to fix it?
m4ff3w
m4ff3w GRM+ Memberand Dork
7/20/08 10:15 a.m.
You can buy replacement gears online, it isn't so much that they melt but they crack and disintegrate with age
When I took mine apart I counted the teeth and found Nylon gears at a hobby shop that matched diameter and teeth number for $5 instead of the $40-$80 online vendors want for them.
minimac
minimac Dork
7/20/08 11:17 a.m.
And don't try the reset while your rolling.
belteshazzar
belteshazzar Dork
7/20/08 1:21 p.m.
Is that all it is? I've owned ONE e30 out of FOUR with a consistently working odometer.
stuart in mn
stuart in mn Dork
7/20/08 1:50 p.m.
It's a common problem with older BMWs, e28 5 series cars do the same thing. You can get the replacement gears from http://www.odometergears.com/. There's a good writeup on the replacement procedure at http://www.mye28.com/viewtopic.php?t=26424
Wall-e
Wall-e GRM+ Memberand SuperDork
7/20/08 2:32 p.m.
It you have some JB Weld and iron filings I'm sure Per could show you how to make your own gears. He's still got about a week of free time left.
Tommy Suddard
7/20/08 8:04 p.m.
Thanks for the help, I'll replace the gears when I replace the dash.
GameboyRMH GRM+ Memberand Dork
7/21/08 7:52 a.m.
You're lucky, on Toyota transaxles (at least the older ones) the replaceable gear on the speedo drive is made of a harder material than the non-replaceable ring on the diff that drives it :(
Per Schroeder
Per Schroeder Technical Editor/Advertising Director
7/21/08 8:34 a.m.
Much quicker/simpler to buy than to make.
3szTUdjA0dwYxro9ggfPMeQ6siUvIniDXvXfL9SypAtrk61Of3lp1rysY0Slv81z
