OldGray320i
OldGray320i Dork
11/17/17 2:16 p.m.
I need to change out the half ps fluid half atf from the roadside repair a couple months back, what's the "easy button" for that?
Disconnect the 1/4 in line on the front of the rack?
Toebra
Toebra HalfDork
11/17/17 4:57 p.m.
If you suck the fluid out of the reservoir, refill with fresh, start the car and turn the wheel back and for to circulate fluid and repeat a few times, you will get enough out.
I seem to remember that Miata power steering fluid is ATF though, Dexron II or something
codrus
11/17/17 5:42 p.m.
Miata power steering fluid is the stuff they sell in bottles that say "power steering fluid" on them.
The last time I flushed mine I did it by cracking the hard line on the pump outlet and spraying it all over the exhaust manifold and turbo at Laguana Seca.  I don't recommend this method. :)
OldGray320i
OldGray320i Dork
11/17/17 6:11 p.m.
 Manual days dexron 2/ATF III
I wish I'd looked at the manual before my roadside repair....
ZhnKcQP2JSIkV0pwS0RWn8aYIpdfUu7zsTNYINY9ooCURtkWKKgDjOI3kbMMf2CY
