Cousin_Eddie
Cousin_Eddie HalfDork
4/24/19 8:41 a.m.
My NA MIata is getting the grouchy rear wheel bearing noise. So I figured I'd ask the experienced folks here.  I planned to Rockauto a couple of Timken brand bearings and a couple of lock nuts today. Is there anything else I should add to the order ?
I know this seems like a BS helpless question but I just started a 48 hour work shift so if I get these parts ordered today they can be in transit and I'll be able to tear into it when I get off work and home on Friday.
Thank you.
NOHOME
NOHOME UltimaDork
4/24/19 8:48 a.m.
Dust seals? Below is what is described as a "Kit" for this job. Maybe a can of brake-klean.
Pete
morello159
morello159 New Reader
4/24/19 1:52 p.m.
I just did the same thing on mine. I reused the factory snap rings but got new dust seals, timken bearings from rockauto and axle nuts. Pretty straightforward, except I ended up taking each wheel end to be local mazda dealer to have them do the pressing. They told me they typically use a die grinder and air chisel to get the inner race off the old hub. I spent an afternoon at a friend's place with a 12t harbor freight hydraulic jack and it wasn't enough to press the bearing out (plus we didn't really have properly sized pressing tools), so be prepared with either a heavier press or be ready to cough up $50/ea to have a pro do it.
sevenracer
sevenracer Reader
4/24/19 4:29 p.m.
When I did mine, the axle seal on the diff started leaking, so I had go back in and fix that.
So, I'd recommend replacing that in addition to the seal on the hub.
codrus
codrus GRM+ Memberand UberDork
4/24/19 7:05 p.m.
If you have ever tracked the car (or have any plans to do so) then I would recommend replacing the rear hubs when you do the bearings.
https://www.miataturbo.net/race-prep-75/when-last-time-you-changed-your-rear-hubs-72613/
Cousin_Eddie
4/24/19 8:24 p.m.
Pete
Good call. I would have missed the dust seals. I'll be sure and get a couple.
Cousin_Eddie
4/24/19 8:26 p.m.
I hope I have it covered. I do have a press and a full OTC Hub Tamer kit. I can usually get something accomplished with those.
Cousin_Eddie
4/24/19 8:27 p.m.
No track time for this car. It has 114k miles on it and I bought it from the 70 year old lady who owned it since the showroom brand new. To say this car has been pampered would be a huge understatement.
ShinnyGroove
ShinnyGroove GRM+ Memberand New Reader
4/24/19 9:01 p.m.
Essential tools: hub puller and slide hammer, snap ring pliers, BFH, large deep-well impact sockets, breaker bar with extension or impact wrench for the axle nut.  I did the job a few weeks ago without a press; it was definitely an arm/shoulder workout.  Had to use the “towel method” on the slide hammer to get the hubs off of the axles, and had to hit one of them with a MAPP torch.  If you have to use the slide hammer as hard as I did, you might want to replace the wheel studs too.  Had to pound the bearings out of the uprights with a 3 lb sledge and a large impact socket.  I used the old bearing as an impactor to drive the new bearing home.
Cousin_Eddie
4/25/19 6:43 a.m.
I sure hope you're from the rust belt. I'm hoping to not take as much of a beating as you did.
codrus
4/25/19 11:43 a.m.
Miata axles and hubs are very reluctant to come apart, it is far from unusual for them to laugh at the standard 20 ton HF press.  I got one apart after beating on it with a slide hammer for 30 minutes, the other one required an air hammer.  This was on a California car that has never seen snow or salt.
Floating Doc
Floating Doc GRM+ Memberand Dork
4/25/19 12:17 p.m.
When, either in miles driven or number of autocross runs, is this a concern for a well cared for and never tracked 1999?
4/25/19 12:26 p.m.
What do you mean by "this"? The drive flange failure? Low to nonexistent. Bearing failure? The car will tell you by making the official bearing failure warning sound.
Floating Doc
4/25/19 12:34 p.m.
Thanks Keith, that's exactly the answer that I needed.
morello159
4/25/19 12:36 p.m.
I too thought about replacing the hubs but mine look fine and the only locally available replacements were made in China. So I reused them.
I've also experienced the siezed axle-in-hub, when replacing my bushings. No amount of pressing or hammering would get it out, including an air hammer. No-rust California car. I ended up getting a new hub from the local miata parts guy.
ZMdj41H859mlKaZrc8whYMB4Rn45DTBp5N3sZfGCwGzFg8MRmeEvzvYvbhs0qLXt
