TeamEvil
TeamEvil Reader
4/17/13 1:59 p.m.
Anyone know the listed track width for a 1984 Mustang and a 1980 Triumph TR8?
I got an idea.
Please, just the listed factory track width for each car, don't need anything more than that.
Thanks,
TC
Rob_Mopar
Rob_Mopar SuperDork
4/17/13 3:00 p.m.
I went to double-check my numbers, but boy do a lot of Fox Mustang references go around in circles on the interweb.
Quick Edit: 1983 Mustang GT track width: 56.6" Front /57.0" Rear From here: 1983 Daytona/Camaro/Mustang review
I thought the TR7 was right around 55. Did some digging and found this but it's hard to read: TR7 Specs
Front track: 55.5" Rear Track: 55.3"
Sorry, couldn't find the same sheet for a TR8.
Hasbro
Hasbro Dork
4/17/13 4:41 p.m.
This says the TR8 is the same.
http://auto-specs.zercustoms.com/t/triumph/1980-triumph-tr8-specifications.html
TeamEvil
TeamEvil Reader
4/18/13 1:05 p.m.
"I went to double-check my numbers, but boy do a lot of Fox Mustang references go around in circles on the interweb"
Do they EVER ! ! ! ! ! ! !
I even started checking other forums, Another doomed fellow was asking about track width and ended up with a lengthy answer about axle thicknesses, like this:
"I'll see if I can dig up some widths on the axles. Here is the info I have and hopefully it will help.
1979 and newer Mustang brake facts:
  • 11"and smaller brakes fit under 15"+ wheels, 12" brakes require 16"+ wheels, and 13"+ brakes require a 17" or larger diameter wheels
  • 1994-1998 Mustang rear axles are 3/4" wider on each side than a 79-93 Mustang.
  • 1999 and newer Mustang rear axles are about 1 7/16" wider on each side than a 79-93 Mustang.
  • 94 and newer Mustang 8.8 will bolt into a 79-93 Mustang but will require brake line adapters.
  • Lincoln Mark7 LSC, SVO Mustang and Fox Body Saleens use a rear axle that is 1.25" wider per side than the 87-93 Mustangs.
  • 94-95 spindles share the same track width as 79-93 spindles.
  • 96 and up spindles have an 8mm wider track width.
  • 79-93 Mustangs all use 9" drums with 7.5 and 8.8 rear axles.
  • 4.0 liter Rangers use a wider 8.8 rear axle and 10" drums."
MAN ! ! ! That's one big load of ass-emission without a scrap of what I needed to know ! ! !
Thanks for the info guys ! ! !
TC
CaJVpseQxnZALijKsCisfpMrWPxQ6ZsIi92pB0if0lqaq1MZhBoRpw0lp6oFjj5o
