Dusterbd13
Dusterbd13 SuperDork
2/19/15 9:15 p.m.
air compressor and table saw are both 110, and therefore on the same breaker. lights are on a different one, thankfully. I had planned on adding a switched outlet to the compressor, as I don't use it as often as most do. pretty much for tires, a scotchbrite pad on my zizz wheel, and a cutoff wheel. also a blowgun. so it wont be used a while bunch. and if I do trip the breaker, I don't have to woerry about being in the dark.
with that said, how hard will it be to add another circuit? I do auto wiring very well, but have never really messed with house wiring beyond replacing ceiling fans/light fixtures.
on the basics of the box:
iv got the ceiling figured out: white corregauted metal .
next decision is the walls. im half tempted to do a "slat wall" system (effectively a while wall of evenly spaced French cleats) so that way I can build and add as needed to suit the eventual changes. I know I cannot forsee everything that needs done aright now, so flexibility should be built in.
any reason not to do the whole shop in a slat wall design from waist level up?
ZNKeTSvvoCTCFXy4GE9rx5LdN2y8kybC5qb0meHDHFHz1rlrZnB3PWDifV4gDXuF
