rodknock
rodknock New Reader
4/11/18 11:09 p.m.
Does anyone know if there will be any issues with topcoating this primer with an acrylic enamel auto paint? I am about to start priming my design capstone model and I really don't want to have to paint it twice because of a compatibility issue. Thanks!
CJ
CJ GRM+ Memberand New Reader
4/12/18 1:04 a.m.
It's odd.  The Rust-Oleum 2 in 1 Primer says it will work under most brands of automotive lacquers and enamels.  The stuff you have says nothing.  Seems like you have a couple of choices.   Spray some scrap with your primer, let it dry, shoot it with your finish, and see what happens.  Or you could call Rust-Oleum and ask what will work.
Personally, the "most" in "most brands of Automotive lacquers and enamels" would spook me.  Think I would do a test spray on scrap regardless...
mikeatrpi
mikeatrpi HalfDork
4/12/18 6:09 a.m.
I had adhesion issues with PPG Omni epoxy primer over Rustoleum primer.  I don't remember exactly what the rustoleum can said.  You should either topcoat with rustoleum, or buy the recommended primer for your acrylic enamel.  Also - acrylic urethane is easier to work with and more durable than acrylic enamel.
FvSl9BAjs22O46hJiVMvbcNFteyikbtjSdwDFnmGNiFDK07IP7uBThFomftNU2Wo
