DILYSI Dave
DILYSI Dave SuperDork
8/3/10 12:38 p.m.
What say ye? Honda D16A6 with factory Multi-Layer Steel head gasket. Engine pulled apart with no headgasket issues. ARP Studs that clamp to 60 ft-lbs instead of the factory 47 ft-lbs. Reuse or don't reuse.
triumph5
triumph5 Reader
8/3/10 12:43 p.m.
ALWAYS use a new head gasket, save yourself a possible headache in the future. Head gasket is designed to be crushed and seal. It's already been crushed, so the sealing part is compromised If this is a challenge car, reuse it. otherwise, no.
splitime
splitime Reader
8/3/10 12:43 p.m.
Will probably work... for the 20 some bucks for a y8 though.. I'd just buy a new one. (or are they more expensive... i'm bit rusty on oem mls gaskets)
And for some reason I keep looking at that 60 ft-lbs and it seems low? Granted... I haven't built a D for like 5-6yrs....
1988RedT2
1988RedT2 Reader
8/3/10 12:46 p.m.
I would never re-use a head gasket, but I guess it depends where you are on your own personal Time vs. Money continuum.
grimmelshanks
grimmelshanks Reader
8/3/10 1:04 p.m.
def no reuse
njansenv
njansenv HalfDork
8/3/10 1:48 p.m.
I've reused a Dodge Neon MLS gasket 3 times. 2.4 turbo, up to 18ish psi, stock headbolts. YMMV.
foxtrapper
foxtrapper SuperDork
8/3/10 2:10 p.m.
I've gotten away with reusing head gaskets many times over the years. Never a recommended practice, and really not worth the few dollars it saves me. But none the less, I've gotten away with it.
That's only when the head gasket came out looking pristine, or nearly so.
Jensenman
Jensenman SuperDork
8/3/10 6:50 p.m.
I don't like the idea of reusing a multilayer steel HG either, since any 'beading' is already crushed. Once or twice I've reused the old composite gaskets (asbestos and steel fire rings) but I have probably just been lucky.
8/3/10 6:57 p.m.
yea.. and it is usually a pig of a job to do the first time.. who wants to do it a second over a cheap part that should have been replaced in the first place?
NYG95GA
NYG95GA SuperDork
8/3/10 7:42 p.m.
I made the stupid mistake of putting a 2.0 DOHC Neon HG on upside down, and once I realized what I'd done, flipped it immediately after only running it a minute.
No problem.
I wouldn't reccomend it, but it was Sunday, my store was closed, and I was broke.
Knurled
Knurled GRM+ Memberand Reader
8/3/10 8:56 p.m.
I'd reuse an MLS before (attempting to) reuse a graphite gasket.
In fact, I have reused MLS head gaskets. Clean with denatured alcohol, spray with Copper-Kote, install.
Pat
Pat Reader
8/3/10 10:28 p.m.
While it may depend on the gasket, the MLS gasket that was in the motor that I ran in my shadow was used three times. It held fine at 34 psi of boost and a 50 shot of nitrous to push the car to a 10.57 @ 135 mph it's last time out. Both times I reused it, I cleaned the hell out of it, inspected it for any damage and hit it with a generous coat of copper spray.
A graphite gasket, I wouldn't consider using. An MLS...if in a pinch, it's likely to be fine.
DILYSI Dave
8/4/10 7:57 a.m.
I pulled the trigger on a new one grumble grumble....
Knurled
8/4/10 8:18 p.m.
How much for your old one shipped to 44070?
Ranger50
Ranger50 New Reader
8/4/10 8:26 p.m.
I've reused those junk gaskets Mopar insists on using without a failure. Again, YMMV.
Brian
Hf3gQEW2r0Jd87n8QV1o0MLfm9LyJ3WbFobhusqYWpivqYCJaqfmyn0WUQwseTLc
