CarRacer
CarRacer Reader
2/15/15 5:47 p.m.
I had to change the thermostat housing to clear the firewall on my engine swap and in the process add another radiator cap to the system. Is this a problem? I'm planning on only running a catch can from the rear cap and plugging the outlet on the front cap, is this a stupid idea?
Thanks.
Don49
Don49 HalfDork
2/15/15 5:51 p.m.
Shouldn't be a problem.
Boost_Crazy
Boost_Crazy Reader
2/15/15 7:25 p.m.
Make sure the cap at the highest point is the cap that feeds the overflow. Use a non relief cap on the other one.
kb58
kb58 Dork
2/15/15 7:58 p.m.
You'll be fine - just do as Boost Crazy recommended.
HappyAndy
HappyAndy UltraDork
2/15/15 8:08 p.m.
Boost_Crazy wrote: Make sure the cap at the highest point is the cap that feeds the overflow. Use a non relief cap on the other one.
Or, if for some reason a non relief cap is not available, the one at the lower point should have the higher relief pressure of the two, preferably by several psi.
wheels777
wheels777 Dork
2/15/15 8:24 p.m.
I usually run two caps. Both get routed vent lines to the overflow. The cap at the higher elevation get a lower pressure rated cap.
mr2peak
mr2peak GRM+ Memberand HalfDork
2/15/15 8:25 p.m.
How about some details. Turbo 4 e30s are cool
carbon
carbon Dork
2/15/15 9:40 p.m.
Should be easy to purge air.
amg_rx7
amg_rx7 SuperDork
2/16/15 12:33 a.m.
That's how Mazda did it on the FD. They also added an Air Separation Tank like the more modern Vette's have.
CarRacer
CarRacer Reader
2/16/15 6:37 a.m.
In reply to mr2peak: http://grassrootsmotorsports.com/forum/build-projects-and-project-cars/1987-bmw-325e-motor-swap-project/83313/page1/
gearheadE30
gearheadE30 Reader
2/16/15 8:03 a.m.
What engine is that?
rcutclif
rcutclif GRM+ Memberand HalfDork
2/16/15 8:22 a.m.
Thread says 4g63?
u3zJX8ZyOooxlSbNYSlkhV14UFcKUCJxa8rOSzJYB2pdNAit9mDQIe4oVcFBMgU3
