6/16/23 3:18 p.m.
In reply to Shavarsh :
Don't use a GM sender?  wink
They come with pigtails because the original ones usually had a different design, the flat four connector is an upgrade from the square four.  The square ones are the ones that burned up all the time.
Shavarsh
Shavarsh HalfDork
6/16/23 6:06 p.m.
No worries there, I'm using a tube style sender to play nice with the cell foam. Does anyone have a favorite brand of gm quick connect to -6 an adapter? Or a preferred cheaper alternative?
6/16/23 7:32 p.m.
Terminology dump: The whole plastic shebang that you bought is also called a "sending unit"
Shavarsh
Shavarsh HalfDork
7/10/23 1:41 p.m.
After a bit of machining we have a dummy plug to keep the return line unobstructed, but still directed into the basket as intended:
ZKqcHP9dWJBvC6zRCYiMTlskZbEajCDiTPgtsXqbP312sTlYE3w9c1J2hr71Fmmz
