My 2006 Miata failed to start yesterday when I tried to fire it up for my third autocross run of the day (15 minutes after prior run). I turned the key and it cranked for a partial engine rotation and then stopped. Lights worked and everything else seemed normal so a couple of grid workers gave me a short push and it started easily.
After the third run was group 2 runs and a break for lunch so I tracked down the issue during lunch and found the 20 amp starter circuit (ST) fuse had blown. I stole the 20 amp defrost fuse and it fired up (1.5 hours later). I then started it for run 4 with no issue (2 hours after prior run). I went to start it for run five and sure enough the fuse popped again (15 minutes after prior run). After another push start I completed run 5 and let it idle so I would not need another push for run 6. I shut it down after the final run and stole the 20 amp wiper fuse which started it for my drive home after group 2 runs, course clean up and awards (2 hours later).
With a cold engine this morning, I started it 10 consecutive times with the standard 20 amp fuse. Later I will go out and try to get it hot and try some consecutive starts to see what happens.
I assume this circuit provides power to the starter solenoid. The Miata forums generally indicate "bad starter" but I am leaning towards a solenoid that is starting to fail. Mazda does not sell a "new" starter, only remanufactured units. They do sell a new solenoid.
it is apparently a pain in the rear to swap the starter due to limited room so if I mess with it I of course would prefer to only do it once.
I think the heat/underhood temps are a factor but not 100% confident on that yet.
Any other testing that you would do before deciding on a course of action? What course of action would you lean towards based on the information presented?
