So, SWMBO's 2008 V6 Mariner is having some somewhat minor issues that I want to resolve before whatever they are becomes a larger issue- and obviously would prefer to do so without dropping it off at the Ford dealership and shelling out hundreds for them to just try and figure it out (and likely replace a bunch of things that ultimately do nothing). It is a FWD-only model, and has about 108,000 miles on it.
She brought to my attention that she'd noticed it vibrating/shaking when she would brake at somewhere around 40mph and was concerned that the brakes needed to be replaced. When I checked the car over before our trip this weekend, I pulled the driver's wheel (where it seemed to be coming from) and looked over the rotor and pad (didn't pull the pads off, just checked thicknesses) and didn't notice anything wrong- I had figured that maybe the rotor was warped or the likes, but was not seening anything along those lines and the pads have plenty of life on them.
I had noticed myself for a while that it seemed to be vibrating a bit more than usual under power at some points, but really noticed it on the drive. It clearly vibrates a LOT when braking from about 50mph down to a bit under 40mph and then essentially goes away. But it ALSO vibrates a good bit when the engine is under a good bit of load, especially when already going at a good clip (i.e., starting up a hill when going 70+ and trying to maintain speed).
Though I'm not certain it's related, there's also a suspension clunk in the front end that I need to figure out too- I had thought/hoped that it was just the sway bar end link nuts loosening up again (because that's an easy & cheap fix vs. most other suspension parts). Not certain if it's related or not, but not ruling it out.
So, my thoughts on what it could be:
1. Wheel bearing and/or CV joint- could account for both vibration and clunking, but I'm not seeing any evidence of the joint boots leaking or being damaged, and I'm not hearing any grinding from the bearings that's my usual telltale that they have issues.
2. Wheel/tire balance- Would think that it would vibrate more consistently, but suppose that it could be a resonance thing. If I do anything with the suspension I'm going to have to get it aligned and would have the shop check all the wheels, but the tires were replaced roughly a year ago... and several have been replaced under the road hazard warrenty since then as well.
3. Something internal in the transmission- could account for the vibrations, but again would expect more consistent issues. What I clearly LEAST want this problem to be.
4. Engine/Transmission mount(s)- could account for both vibration and clunking
5. Strut/strut mounts- most obvious potential source for the clunking- I thought I had replaced all of the struts & shocks a few years back, but can't find any documentation to support this...
It is of course quite possible that there are several unrelated things causing what we're seeing...
Thoughts or suggestions?
