Gearheadotaku (Forum Supporter)
Gearheadotaku (Forum Supporter) GRM+ Memberand UltimaDork
7/14/24 8:41 p.m.
10 years ago I took a welding class and bought a new Weldcote helmet. It has 4 flash sensors and replaceable sheilds for the glass. Was touted as a good "bang for the buck" unit. I liked it in my class, but now, years later its not so good. I use once maybe twice a year and all I can see is the arc, nothing else. Adjusted what i can but cant weld what i cant see!
Ideas?
Streetwiseguy MegaDork
7/14/24 8:46 p.m.
I think they deteriorate.  I've bought one every five years or so, and use them weekly, I guess.  Not quite daily.
triumph7
triumph7 Dork
7/15/24 12:56 a.m.
In reply to Gearheadotaku (Forum Supporter) :
Does your shop have as much light?  Have you tried aiming a shop light at the weld area?  The newer helmets offer a lot better view of the rest of the weld area.
7/15/24 7:01 p.m.
Yeah I put as much light on as I can. Guess I need more. Also on the bench you can get your face closer vs. Arms length when its on a car.
californiamilleghia
californiamilleghia UberDork
7/15/24 7:03 p.m.
Is there anyway to test an older one ?
7/15/24 7:36 p.m.
If you go to use it and it doesn't dim, it's bad.
Sounds almost too easy, I know smiley
You may be able to test this without welding, though.  Flashing lights are sometimes enough to set them off.
DeadSkunk  (Warren)
DeadSkunk (Warren) MegaDork
7/15/24 7:41 p.m.
I used mine for the first time in 3 years to view the eclipse. It still worked fine.
Z0EUTC3Azb7Gymh2MjdNWW0w55f2SxNIv3I7MKSIKRHNlzzXOd35xOqTT57hGcPq
