10/6/21 7:22 p.m.
Found an auction featuring a Precision Instruments torque wrench.  Dial type. From what I've found, they seem to be well made, although I suppose anything is more precise than the Harbor Freight hammers I currently have. Opinions?
Cactus
Cactus HalfDork
10/6/21 8:08 p.m.
I remember GRM testing torque wrenches a year or two ago and I remember the HF ones coming in close enough that I'd be comfortable using them on internal engine fasteners.
Jesse Ransom
10/6/21 8:23 p.m.
I was happy with my HF torque wrenches, then one spontaneously disassembled itself. I replaced it with a Precision Instruments unit. I don't recall the exact path of research that led me there. I've used it a few times, but not extensively. I haven't tested it for accuracy.
The one thing that sort of surprised me is that you can't use it on LH threaded stuff. It has a non-reversing ratchet, IIRC. I'd have thought the torque-measuring device could easily be made symmetrical, but I don't even know what it looks like inside, so that may be an insane expectation. Perhaps it's to do with it being a split beam type device? I guess another split beam thing is that I don't have to pull the adjustment out between uses, but that never bothered me much.
Mine's a 1/2" drive and looks rather different from the pictured unit. Er, even apart from being click type and not dial. At least with a small one like that you've got a better chance of keeping your head pointed at the dial during use. I've got an old Craftsman needle type 1/2" as well, and it's fine excepting of course that your head's usually in the wrong location and pointed the wrong direction to read it unless you're doing something on the bench.
10/6/21 8:35 p.m.
In reply to Cactus :
Test torque wrenches we did: Choosing a Torque Wrench
Jesse Ransom
10/6/21 11:53 p.m.
Credit where it's due: while as noted I don't recall all the inputs, that article was definitely part of the process.
Professor_Brap (Forum Supporter) UltraDork
10/7/21 8:13 a.m.
I like my precision instruments torque wrench, It tested close enough for my uses on the tool truck.
10/7/21 8:29 a.m.
In reply to Jesse Ransom :
Awesome, glad that it helped. JG made buying a torque wrench fun.
GjvjIE9Gtq5HiCbt0AEIRed9MqwtL30vV80SpliLyRnOjxVVooLHK61S8FMedZFh
