jamscal
jamscal HalfDork
4/24/09 8:53 a.m.
It's for a 95 Jeep Grand Cherokee V8.
I'm about to install this condenser and don't know if I need a special tool, if it just presses on, or what?
The one in the vehicle seems to be crimped around the edges.
There is a small spring that runs around the inside of the fitting. Visible in the pic under the green o-rings.
Thanks,
James
warpedredneck
warpedredneck New Reader
4/24/09 9:03 a.m.
there is a set of plastic fittings that wrap around the out side of the fitting then you "push/slide) it up, these are also used in fuel lines napa should have it, also theres a company called lisile(i think) i have a set in my tool box if i think about it i'll bring them home and put up a pic
ignorant
ignorant SuperDork
4/24/09 9:03 a.m.
To connect just press together.. They are a bitch though..
To separate you need a set of A/C line tools.
http://www.tooltopia.com/index.asp?PageAction=VIEWPROD&ProdID=36873&utm_source=yahoo_shopping&utm_medium=cse&utm_term=41500&utm_campaign=yahoo_18
Like that.
4nCRTGvNOBEfJNehZlA1OrMDdRRW8xQYqVPI9eNFN4t977DPnhAyRWGqEixHeDCA
