With these rules?
This is an open wheel tube chassis 4 cyl. circle track class that I'm starting to look at seriously.
Front engine - rear wheel drive only.
Any 4 cylinder, single cam, 2 valve per cylinder up to 2400 cc.
Mass produced production car heads only.
Wet sump oil system only.
Two barrel carburetors, gasoline and natural aspiration only. No fuel injection, turbo blowers or nitro.
Max. engine set back to be 20" from center of front wheels to front of engine block.
Weight of car with driver after feature to be : Ford 2300 cc, hydraulic lifter engine -1700 lbs.
All other .85 lbs per cc
Honda A20 out of an 80s Accord? 120 hp stock. With the displacement correction, you might look at a 2tc as well.
Edit, scratch the Honda, it's a 12 valve.
Can you sleeve em? If you can that would open up a few more options.
cxhb
Reader
8/7/10 8:21 a.m.
The ford 2300 pinto gets my vote.
Iron Duke? A gazillion were made and parts are still available.
The Ford 2300 was a weezer though, and HEAVY. Datsun Z24 gets my vote, or maybe Nissan KA24 (from the pickup) if you can find a 2Bbl manifold for it.
Jay
Dork
8/7/10 9:33 a.m.
Porsche 914 2.0 or some kind of stroked ACVW lump. Save the weight & remove failure points of a water cooling system.
Interesting.
I thought about the air cooled motors, but they're pushrod, and I'd rather have water cooling than pushrods. Not big on the 2300 Ford motors, and the Duke is too big (and pushrod again) at 2500 cc.
I was thinking 1.8, or 2.0 VW. Well built, stout motors that can take RPM's, with a good supply of aftermarket parts. Manifolds shouldn't be a problem, I can make those.
I think a BMW m10 with an s14 crank, high compression, lumpy cam, and a single 45 or 48 dcoe weber would scream. You could get close to 2.4 and you have some very useable power.
For some reason, that doesn't sound budget friendly.
Maybe a 2.2 Chrysler? Are good cores still available?
watercooled vw 8v. dirt cheap, simple, breath pretty well from what i understand
Miata BP
240sx/Hardbody KA24E/DE
Nitroracer wrote:
Miata BP
BP has twice the legal valves.
F2 from the old B2200 would work.
tuna55
HalfDork
8/7/10 4:15 p.m.
B20 overbored from an old Volvo. Don't hate on pushrods, they were good for 7 grand stock. You can overbore them to the point of taking Ford 4.6 pistons (even the wrist pin is the same) and easily make a 150 hp motor.
Vigo
HalfDork
8/7/10 5:40 p.m.
The short answer is.. yes, thousands of them.
The 2.2 dodge is pretty damn reliable and hard to break, too. You can get a carbed one up to ~130 hp pretty easily just by building the exhaust manifold, which you would do anyway, and then minor porting of bits here and there. People going all out on them have done well over 200 hp n/a, but that info is hard to find because all the info on the turbo version drowns it out on the internet. Its a sohc 8v non interference motor as delivered, but you can quickly turn it into an interference motor by mixing early pistons, later head, and a little cutting to get well over 10:1 compression on everyday junkyard parts.
By the formula, it looks like you could use a 1.6L motor and run your car weight at 1360 lbs. I don't know if I'd be looking at the larger displacement engines suggested here.
Food for thought.
http://www.race-cars.com/engsold/toyota/1111890981/1111890981ss.htm
Ford 2300, because it already is a race engine in the US and you can get race parts for it.
Known quantities are a good thing!
Not to mention, that the weight break is such that a 2300 powered car weighs what a 2-liter anything-else does. That's 300cc more torque for you.
fiat 1300/1500 128 series engine out of an X 1/9?
L series Datsun? Way lighter than the 2300 (aluminum head, for instance), plenty of race stuff available, easily carbed. Available in 1600cc, 1800cc and 2000cc versions.
Maybe a Toyota 22R for the same reasons as the Datsun L series. I dunno how much hotrod stuff is out there for that one, though.
Long shot, if you can find it: Mercedes 190E four banger with a 5 speed. Tough motor but I dunno how easy it would be to carb or etc. You'd probably have to build your own intake.
There are more choices than I had originally thought. I'd bet the BMW's would be fast, but also out my (low) budget. If it were 10 years earlier, I'd be thinking more about the 2.2 Chryslers.
I heard about a race ready, competitive car last night. 2.3 (I'm assuming) hyd. motor. Although I have little interest in the 2.3, that's a pretty attractive option, at 1700 lbs. The guy wants $4k for it, ready to race, and that's with a quick change rear end. I'll have a look this week.
This is the class
WOW!! That looks awesome.
