I can't find the rear or bottom veiws - any suggestions? It's an 04 EP3.
Cool site for a bunch of cars: http://carblueprints.narod.ru/
you've already found my only suggestion.
If you're good with illustrator, you might be able to make/trace an actual photography with good results. What are you using them for?
Tom Heath wrote: If you're good with illustrator, you might be able to make/trace an actual photography with good results. What are you using them for?
For designing body mods. The side and front are the most important. I erase out the lines that are in the way, make a bunch of copies and scribble away. My walls are starting to look as if I'm a car stalker.
I'll put it up in a bit, after some computer fixes. It's just in pencil and rough. But I do like it. Came out the way I pictured it in my mind.
http://www.the-blueprints.com/index.php?blueprints/cars/honda/5043/view/honda_civic_3_door_2005/
http://www.the-blueprints.com/index.php?blueprints/cars/honda/9013/view/honda_civic_si_3_door_2002/
jrw1621 wrote: http://www.the-blueprints.com/index.php?blueprints/cars/honda/5043/view/honda_civic_3_door_2005/ http://www.the-blueprints.com/index.php?blueprints/cars/honda/9013/view/honda_civic_si_3_door_2002/
Same pics they have but the resolution is much better. Thanks!!!
