dj
dj Reader
10/16/18 8:38 p.m.
Well I done did it now. I spilt oil on the driveway during an oil change the other day and made a mess. I tried to sop it up with paper towels and then scrub with dish and laundry detergent. That didn't work. Next I tried wd40 then water, still stained.
What will really work? Rent a pressure washer or just try simple green? What would you do, GRM?
EastCoastMojo
10/16/18 8:50 p.m.
Buy the cheap non-clumping cat litter, throw a copious amount on the stain, grind it in with your shoes and leave it for a few days.
Patrick
10/16/18 8:56 p.m.
Mineral spirits
Tyler H
Tyler H GRM+ Memberand UltraDork
10/16/18 9:19 p.m.
Just did this at my new house. Brake cleaner and lots of paper towels.  Do one small area at a time.
10/17/18 6:45 a.m.
... and then hit it with Dawn dish detergent and hot hot hot water.
gunner
gunner GRM+ Memberand HalfDork
10/17/18 7:14 a.m.
After all this, there may be a small amount that will stubbornly be there. cover that in baking soda and leave it. let the rain wash it away.
LanEvo
LanEvo GRM+ Memberand HalfDork
10/17/18 7:46 a.m.
Did this at my parents’ house a few years ago. I bought a commercial concrete detergent from Home Depot. Pour it on. Let it soak. Then hose off. I had to repeat it 2-3 times, but it eventually cleared completely.
As far as I know, there was nothing really special about the concrete cleaner. Looked, smelled, and felt just like dish soap.
44Dwarf
44Dwarf UberDork
10/17/18 11:55 a.m.
Gunk brand used to sell a powder you sprinkled on then wetted it would go from Yellow to Bright green looked like anti-freeze scrub with a stiff bush ( like those used for sealing pavment) and hose off.  We used to clean the shop bays at the Mobil I worked in every sunday.  Looks like it is /was Gunk SW2 Swab
Knurled.
10/17/18 12:09 p.m.
Stick some absorbent mat over it and drench it with boiling water. The mat will keep the water there,and oil floats on water...
Crazy but works.
Vigo
Vigo UltimaDork
10/17/18 2:01 p.m.
Ahh, the good old yellow powder. It may have made you wonder about your life expectancy after you breathed a little of the odor coming off it, but damn if it doesn't clean concrete!
Antihero
Antihero GRM+ Memberand Dork
10/17/18 2:04 p.m.
Concrete is pourous, it depends of how well finished it is but ive had luck with kitty litter
44Dwarf
44Dwarf UberDork
10/17/18 2:23 p.m.
In reply to Vigo :
ph is 12....
Funny part about it turning green we had someone call the popo on us saying we were using antifreeze and washing it down the drains...
EvanB
EvanB GRM+ Memberand MegaDork
10/17/18 2:41 p.m.
44Dwarf said:
In reply to Vigo :
ph is 12....
That is the reason we stock a white version at work now. It just turns milky white instead of green.
GGIIUucPn7XAyUw4vudcv1m2jkdArkaugRpLt8K6r5SoKLpfVMmVvMnbV614gr5k
