Moparman
Moparman Dork
5/8/13 5:31 p.m.
The LSD makes a world of difference. You can begin applying more power before the car settles coming out of a corner without that dirt-track wheel spin feeling. It is pretty much turn the wheel, apply the power and go.
FSP_ZX2
FSP_ZX2 Dork
5/8/13 9:10 p.m.
We took the car to a PDX at Road America in October, right after the LSD and Flywheel went in...it had a tired motor and an exhaust leak, so it was down on power, but was still giggly fun handling-wise. Was getting back on throttle before apexes and just pulling out of the turns...I can't wait!
ZX2 PDX in car at RA
PHeller
PHeller UltraDork
6/3/13 6:40 p.m.
This thread has got me looking at ZX2's again. I enjoyed mine, did everything it needed to do, and saved my life when it sacrificed it's own.
The biggest perk being that everything I've got on my wagon would swap over to the ZX2, and I still could break even after selling the wagon.
It aint no Honda Fit, Ford Fusion, or any other modern car, but it's cheaper than similar year Civics. And at least it's got OBD2, unlike the 93 Escort.
Alan Cesar
Alan Cesar Associate Editor
6/3/13 10:34 p.m.
PHeller wrote: This thread has got me looking at ZX2's again. I enjoyed mine, did everything it needed to do, and saved my life when it sacrificed it's own. The biggest perk being that everything I've got on my wagon would swap over to the ZX2, and I still could break even after selling the wagon. It aint no Honda Fit, Ford Fusion, or any other modern car, but it's cheaper than similar year Civics. And at least it's got OBD2, unlike the 93 Escort.
Actually, the rear suspension on those Escorts is more sophisticated than the twist-beam on the current Fiesta and Mazda2.
PHeller
PHeller UltraDork
6/9/13 10:20 a.m.
Does Bilstein make inserts for the BG Chassis?
EDIT: Answer is not any more.
EDIT#2:
The MX-3 Koni Red Inserts are apparently designed with a shorter length spring in mind, I'd be worried that running these on stock ZX2 springs would overextend the struts, which in my experience (S/R Tokicos) can be bad.
Swank Force One
Swank Force One MegaDork
6/9/13 11:50 a.m.
Look at 2nd gen Probe stuff.
FSP_ZX2
FSP_ZX2 Dork
6/9/13 3:14 p.m.
My understanding is that BJ Protege (99-03) stuff can be easily made to work as well.
PHeller
PHeller UltraDork
6/12/13 7:53 p.m.
FSP_ZX2, I tried emailing you. Didn't work.
I'd like to try the RX7 ball joints on my otherwise stock (for now) ZX2.
How much camber will the ball joints by themselves provide?
FSP_ZX2
FSP_ZX2 Dork
6/12/13 10:35 p.m.
PHeller wrote: FSP_ZX2, I tried emailing you. Didn't work. I'd like to try the RX7 ball joints on my otherwise stock (for now) ZX2. How much camber will the ball joints by themselves provide?
See your PM for my email.
I have not tried this trick but am intrigued by it. We have slotted the strut mounts (the clevis/ears) on the strut body for our camber adjustment. We also run "caster paltes" (camber plates turned 90)...by doing this we don't need a ton of static negative camber--just over 2 is all. It helps with braking and even more with forward bite off corner to keep the tires a little more level. We just put some new DA coilovers on--and the RX7 balljoint trick might save is the trouble of getting out the carbite
iceracer
iceracer UberDork
6/13/13 7:57 a.m.
On my ZX2SR, I was lucky enough to get one of Ford Racings Camber adjustment kits. Later discontinued. It consisted of a cutter to enlarge a hole in the strut bracket and an eccentric bolt.
After turning the strut mounts 90 degrees to in crease caster, I then found a set of offset control arm bushings. I now had almost double the stock caster. big improvement and less negative camber needed. Much as FSP-ZX2 has said.
NHwo7oh3Pj4sSajkuJFZcFSeZS1mNW4r4XIvAsInG1vVEuaN7Ie4u9RltXmI8a6R
