1 ... 6 7 8 9 10 ... 13
Justjim75
Justjim75 SuperDork
5/27/21 8:57 a.m.
What's with the cargo fork brace?  Looks like it's resting on the tire, what is it and what does it do?
Professor_Brap (Forum Supporter) UltraDork
5/27/21 9:00 a.m.
In reply to Justjim75 :
It rest on the top of tire and bottom of triple tree. You put it there when bike it strapped down so you don't have to squish suspension.
Justjim75
Justjim75 SuperDork
5/27/21 11:41 a.m.
In reply to Professor_Brap (Forum Supporter) :
Oh E36 M3!  Where do I get one?
Edit, is there one for street bikes?  Lol I need one for lower triple tree to fender top
5/27/21 12:02 p.m.
Got it from a local motorcycle shop. Was like $10. Well worth it. Ill snap a pic of how I tie down street bikes for ya
thatsnowinnebago
thatsnowinnebago GRM+ Memberand UltraDork
5/27/21 12:14 p.m.
Professor_Brap (Forum Supporter) said:
So a downfall of drz ownership is the damn horn. Tired to get mine working, bike didn't have one with i got it. The wires to the horn arnt broke, the issue is in the switch. Took apart the switch and found the switch bad. Hit up amazon for a Simi permanent solution.
I never use a horn on this bike so it works perfectly.
I'm imagining someone doing hooligan supermoto stuff, ringing that little bell the whole time. It's hilarious. Ring ring, it's wheelie time!
5/27/21 8:12 p.m.
In reply to thatsnowinnebago :
Did a big ol stoppie up to my mom today and when I stopped I rang the bell.
6/23/21 8:00 a.m.
Had to pull it apart to fix a valve cover leak, was leaking where cam humps where. New valve cover, new bolt gromets last time I did it. A thin layer of rtv seemed to do the trick.
6/24/21 7:20 a.m.
Rear master cylinder reservoir was looking gunky.
Finest Chinese reservoir to the rescue.
Fresh fluid and feels wonderful.
7/6/21 7:39 a.m.
100 miles on Saturday running around getting parts to fix floor in glh. Buzzing around town on a supermoto with a backpack and a beautiful day is nothing better.
fatallightning
fatallightning Reader
7/6/21 7:44 a.m.
A thousand? Or a hundred. Either way, can't beat a good day on the bike.
7/6/21 10:02 a.m.
In reply to fatallightning :
100, ain't no way I could do 1000 miles in a day on the Drz.
Justjim75
Justjim75 SuperDork
7/6/21 11:23 a.m.
100 around town is usually on and off a dozen times, lots of stop and go etc.  100 on the highway is meh, but around town that's getting after it, I know, I do it too except on a bike less ideal for curb jumping
7/6/21 11:54 a.m.
It doesn't help I had to run 2 towns over twice  that's 10 miles one way. It is really the best run around bike.
Justjim75
Justjim75 SuperDork
7/12/21 11:07 p.m.
Progress reports are due on those bikes Brap.....
7/13/21 5:11 p.m.
I'll go through and do them all tonight. Drz is getting the milage pounded on and having a riot doing it. It just runs and runs and runs almost due for a oil change. Need to do a plug it's is cold starting a little hard.
Also got a new bell. I chuckle every time I see it.
7/23/21 12:50 p.m.
Not gonna have the drz for a week or two. Getting the suspension redone.
thatsnowinnebago
7/23/21 2:29 p.m.
Nice, what exactly are you upgrading?
7/23/21 3:23 p.m.
Fork seals, fork bushings, springs, valving and fork oil. Shock spring, oil and seals.
catzop
catzop New Reader
8/3/21 1:01 a.m.
it sure looks effective in the video! How does it compare to the old and busted?
8/3/21 5:58 a.m.
In reply to catzop :
Unsure what your referring to.
8/9/21 8:19 p.m.
Suspension is resprung and rebuilt and man I love this bike even more. At 285lbs the bike felt soft, so had my buddy who is a racetech certified suspension tuner.
Rear shock
6.3 spring rate race tech
15 weight shock fluid
High speed adjust 1.5
10 compression
12 rebound
165 pounds nitro
Sag 100
Front forks
15 weight fork fluid
8 compression
10 rebound
Bike feels more balanced and doesn't bottom out over large curbs. In the corners it is less twitchy over bumps.
8/10/21 9:48 a.m.
front brake light switch was interment,Honda OEM to the rescue for $12.
8/11/21 10:46 a.m.
Got bored at work and cut out a ignition relocation bracket.
catzop
catzop New Reader
8/12/21 2:34 a.m.
I want bark bisters for my HD, and link to Chinese levers?   vidmate instasave
8/12/21 8:44 a.m.
They are canoe brand
VXFtNZPv3gCCNaV3fiszccnhVVZ6vvuXO5SwQYW6sLXhmr5B1cBEdSClmggLt3xM
