slefain
slefain UltimaDork
8/3/23 4:21 p.m.
So my Freebike (here https://grassrootsmotorsports.com/forum/motorcycles-and-bicycles/got-a-wrecked-vivi-folding-e-bike-now-what-to-do-with-it/241579/page1/) is in need of a new wheel. I found a new fork on Amazon, no problem. But a front wheel seems to elude me.
I found one one on AliExpress possibly:
https://www.aliexpress.us/item/3256804154861593.html?spm=a2g0o.detail.0.0.87801583fCp9fT&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40050.281175.0&scm_id=1007.40050.281175.0&scm-url=1007.40050.281175.0&pvid=de22aeaa-799d-4c80-b056-d6c4cbc6df89&_t=gps-id:pcDetailTopMoreOtherSeller,scm-url:1007.40050.281175.0,pvid:de22aeaa-799d-4c80-b056-d6c4cbc6df89,tpp_buckets:668%232846%238110%231995&pdp_npi=4%40dis%21USD%2131.20%2123.4%21%21%2131.20%21%21%402101ea8c16910932403287436ec8b5%2112000028824968818%21rec%21US%21%21A
Or maybe this one on eBay:
https://www.ebay.com/itm/115495548170?hash=item1ae412350a:g:s-oAAOSwXi9imFc0&amdata=enc%3AAQAIAAAA8J9jkrtZWVcYGJag4UOMQ04irMCiMKNCm2kFzKSIzy19AQRXtTRfwygzICuSht%2B0O9zPbwP1ClsthycY5m4MuLf7p4inVxYLN2s19sJtLRvU2tmkarzFfTD0dMM8zDKoN01Frh3fKSTLWx2RRzDcdGQlRA51jfzIqp1sX3%2BY3%2BzJIYDYksHOhlNAQdM%2F7KFuUPXIpxdLH0xtBhO25%2F2EDuUOeFl10jwrdf9VorqP2rYYqqzGnX7Rl59TMu9BlQvKN0vonjUYLu0W0BOBZQKPXd6Z4ncYVp6aUnLfvN4et%2BBCSV2TWVkYVpGXMEmE7%2BcC4A%3D%3D%7Ctkp%3ABFBM6sLD0Ldi
I just feel like I'm missing something obvious here. I contacted the bike manufacturer and they don't sell just the front wheel. I don't want to overlook something simple like "just grab a rear wheel, yank the sprocket and bolt on this disc brake adapter" kind of simple solution.
Jesse Ransom
8/3/23 4:42 p.m.
EDIT: Sorry, answering while distracted again and I lazied out of following the links. If you can verify the axle diameter and fork spacing width I think you're in with a shout. Maybe see if you can ascertain anything about the lateral location of the disc mount? I failed to absorb what you'd found.
Take it to the local bike shop and have them lace up a 20" rim to a disc brake hub? It won't be as cheap as AliBayEtc, but it will exist. Unless said bike has a super-funky proprietary fork width or something; it's my impression that a nontrivial number of the flood of cheap ebikes have bits that don't interchange with the existing bicycle world.
matthewmcl
matthewmcl Dork
8/3/23 5:03 p.m.
A lot of recumbent bikes use 20 for the front wheel and run disks. Does adding that search term help find anything? It is looking like it does, but I could be missing something, too.
Try Prowheelbuilder dots comz - a bike shop in Cumming, GA.  They've build great wheels for me.  I would call if nothing is listed on their site.
Oapfu
Oapfu GRM+ Memberand Reader
8/3/23 9:02 p.m.
Everything I could find is more $$ than I personally would want to pay.  I seriously would NOT have expected a front wheel to be that difficult to find!
Some info from an older MTBR thread also looking for 20in disc brake wheels:
  • Normally the front hub should be 100mm wide, but some folding bikes had 74mm hubs?  Double check/ measure your replacement fork.  Rear hubs are normally 135mm wide, so you cannot use a rear wheel in front.
  • There are two different versions of nominally "20 inch" rims.  The ISO or ETRTO (European) size designations are the actual diameter of the bead (measured in mm): "451" and "406".  Tires obviously will not interchange.  Just for convenience you might want to get a front wheel which is the same as your rear wheel.
slefain
slefain UltimaDork
8/4/23 10:15 a.m.
Thank you everyone for verifying I'm just not bad a parts scrounging. I'm going to measure the bike forks and see which wheel I need.
qxTrkShgGiO8LStqaaELEUanGoZz62iNvtdNwOPrEUgcPuDb3n9VrmTodQAmym0b
