Carbs on, plugs changed, valve clearances checked, and carbs synchronized.
Fired right up and damn near idled perfect.
Did have to bypass the clutch switch, it is pretty rought.
Let's start with part one of pile of parts.
Carbs are good, new fuel like and filter, plugs, oil changed
One caliper was frozen solid, needed the grease gun treatment, other came apart with air. Ended up using a brembo rcs19 master cylinder I got in a big parts buy for the front since the factory master is cracked. Rear brake got fresh fluid and is good to go. Had to order a bracket for the brake fluid reservoir since I can't find mine.
Mounting the front tire.
Shifter
Did a chain and sprocket since the OEM chain was shedding oring dust, did a 15/47.
Took the cluster apart to fix speedo needle.
Also some of the small stuff I have fixed was a clutch cover oring, missing hardwear, and some grab handle delete plugs.
That hose running from the front rezzi to the master cylinder looks huge. I guess that wouldn't hurt performance or feel though. Good looking lever.
In reply to GCrites :
Correct size hose (I think, it's what came with it) way to long, this is a temporary fix so I could cause some mayham on my birthday.
Here is some 3rd gear limiter burnout action to kill the 23 year old rear tire.
Told the boys that it would either, blow up, overheat, or explode the tire. Well we exploded the tire and had a fire. So that's a win in my book.
Here is a product to mount your front brake reservoir.
https://www.kurveygirl.com/products/kurveygirl-universal-reservoir-bracket-ladybird-style
Changed the oil, and sent off a sample. Also put on master cylinder bracket.
Budget:$1188 total so far including purchase price of bike.
Oil change 2x $22
New tank/new cap $295
Carb rebuild/air filter $36
Fuel pump/filter/line$10
Plugs cr8e $8
Tires/valve stems$120
Chain and sprocket 15/47 $122
Brake (brembo master, caliper rebuild, line, pads) $240
Shifter $15
Tail section plugs $20
Got a bunch more parts I haven't used yet, so haven't put them in budget.
There was so much fluid in the hose before that you almost want to pour it back in the bottle! I am nearly that cheap
I did reuse it to bleed the rear brake. It seems to work pretty good after a bleed.
New used mosfet regular/rectifer to help save the stator.
Another successful ride.
Plus a smoked plate found during rear end disassembly.
Also got after it a little and got it leaned over.
which R/R did you use?
Professor_Brap (Forum Supporter) said:New used mosfet regular/rectifer to help save the stator.
So ended up with a ohlins rear shock......
Its not the final install more of a make sure it will fit/figure out where I'm mounting the reservoir.
It's also coming out again for a rebuild.
Was thinking somewhere where I got it zip ties or go super fancy and put it under the pillion seat by the cdi box.
Yesterday was a fun day.
100% bone stock minus a shim under the needle.
AFR is beautiful and made stock power.
Been a while, got way to many irons in the fire.
Rear suspension: cleaned and greased swing arm bearings, ohlins got new seals and fresh fluid and a recharge, and setup for my weight.
Forks: powder coated lowers, 0.90 kg/mm racetech springs, gold valve emulators, bushings, seals, 15w oil.
I can't get over how well it rides now.
